查看: 2330|回复: 2
安装synopsys,已经生成license,但dc/dc依然无法使用
发表于 2017-8-15 19:08:20 | 显示全部楼层 |阅读模式
19:01:24 (snpslmd)
19:01:24 (snpslmd) Licenses are case sensitive for TE_CATS
19:01:24 (snpslmd)
19:01:24 (snpslmd) EXTERNAL FILTERS are OFF
19:01:24 (lmgrd) snpslmd using TCP-port 54192
19:01:24 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  archprod  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synopsysd  tmald  vcsd
19:01:25 (snpslmd) ------------------------------------------------------------------
19:01:25 (snpslmd) Checking the integrity of the license file....
19:01:25 (snpslmd) Valid SSS feature found.
19:01:25 (snpslmd) The feature is needed to enable the other keys in your license file.
^C
[root@dcclab ~]# dc
bash: dc_shell: command not found...
发表于 2017-8-16 22:14:10 | 显示全部楼层
回复 1# deeeeepblue
   环境变量未配置,不知道你用的bash 还是csh
 楼主| 发表于 2017-8-21 11:28:22 | 显示全部楼层
回复 2# 1w1w1
   bash
GMT+8, 2025-12-18 20:21 , Processed in 0.012800 second(s), 4 queries , Gzip On, Redis On.
