查看: 8448|回复: 9
安装synopsys遇到No features to serve, exiting
发表于 2017-8-6 22:42:51 | 显示全部楼层 |阅读模式
大家好,本人剛開始接觸EDA TOOLS  遇到下面問題,不知道是否有經驗的大大可以協助,謝謝
[root@localhost license]# lmgrd -c laker.dat
7:33:08 (lmgrd) -----------------------------------------------
7:33:08 (lmgrd)   Please Note:
7:33:08 (lmgrd)
7:33:08 (lmgrd)   This log is intended for debug purposes only.
7:33:08 (lmgrd)   In order to capture accurate license
7:33:08 (lmgrd)   usage data into an organized repository,
7:33:08 (lmgrd)   please enable report logging. Use Flexera Software, Inc.'s
7:33:08 (lmgrd)   software license administration  solution,
7:33:08 (lmgrd)   FLEXnet Manager, to  readily gain visibility
7:33:08 (lmgrd)   into license usage data and to create
7:33:08 (lmgrd)   insightful reports on critical information like
7:33:08 (lmgrd)   license availability and usage. FLEXnet Manager
7:33:08 (lmgrd)   can be fully automated to run these reports on
7:33:08 (lmgrd)   schedule and can be used to track license
7:33:08 (lmgrd)   servers and usage across a heterogeneous
7:33:08 (lmgrd)   network of servers including Windows NT, Linux
7:33:08 (lmgrd)   and UNIX. Contact Flexera Software, Inc. at
7:33:08 (lmgrd)   www.flexerasoftware.com for more details on how to
7:33:08 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
7:33:08 (lmgrd)   for your enterprise.
7:33:08 (lmgrd)
7:33:08 (lmgrd)
7:33:08 (lmgrd)
7:33:08 (lmgrd) The license server manager (lmgrd) running as root:
7:33:08 (lmgrd)        This is a potential security problem
7:33:08 (lmgrd)        and is not recommended.
[root@localhost license]#  7:33:08 (lmgrd) FLEXnet Licensing (v11.9.0.0 build 87342 x64_lsb) started on localhost.localdomain (linux) (8/6/2017)
7:33:08 (lmgrd) Copyright (c) 1988-2010 Flexera Software, Inc. All Rights Reserved.
7:33:08 (lmgrd) US Patents 5,390,297 and 5,671,412.
7:33:08 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
7:33:08 (lmgrd) License file(s): laker.dat
7:33:08 (lmgrd) lmgrd tcp-port 27000
7:33:08 (lmgrd) Starting vendor daemons ...
7:33:08 (lmgrd) Started snslmgrd (internet tcp_port 55157 pid 5166)
7:33:08 (snslmgrd) FLEXnet Licensing version v11.9.0.0 build 87342 x64_lsb
7:33:08 (snslmgrd) License server system started on localhost.localdomain
7:33:08 (snslmgrd) No features to serve, exiting
7:33:08 (snslmgrd) EXITING DUE TO SIGNAL 36 Exit reason 4
7:33:08 (lmgrd) snslmgrd exited with status 36 (No features to serve)
7:33:08 (lmgrd) snslmgrd daemon found no features.  Please correct
7:33:08 (lmgrd) license file and re-start daemons.
7:33:08 (lmgrd)
7:33:08 (lmgrd) This may be due to the fact that you are using
7:33:08 (lmgrd) a different license file from the one you expect.
7:33:08 (lmgrd) Check to make sure that:
7:33:08 (lmgrd) laker.dat
7:33:08 (lmgrd) is the license file you want to use.
7:33:08 (lmgrd)
发表于 2017-8-6 23:59:59 | 显示全部楼层
licence有问题
发表于 2017-12-21 07:12:44 | 显示全部楼层
亲,这个问题解决了么?
发表于 2020-7-30 10:57:41 | 显示全部楼层
发表于 2021-1-8 17:27:51 | 显示全部楼层
我也遇到了
发表于 2021-1-21 22:34:15 | 显示全部楼层
同遇到,不知道如何解决
发表于 2021-6-21 21:45:57 | 显示全部楼层
有人遇到这个问题吗,怎么解决
发表于 2024-12-25 11:21:39 | 显示全部楼层
过了几年了,大家解决这个问题了吗?我刚遇到
发表于 2025-5-16 09:12:15 | 显示全部楼层
遇到同样现象,是系统时间比license生成时间晚导致的
发表于 2025-11-4 10:12:40 | 显示全部楼层
看看license的起止时间,是否系统时间不在这个范围内?
GMT+8, 2025-12-14 22:27 , Processed in 0.019139 second(s), 5 queries , Gzip On, Redis On.
