查看: 1004|回复: 0
[招聘] Cadence招聘Principal/Lead Application Engineer -数字前端
发表于 2017-8-1 16:46:23 | 显示全部楼层 |阅读模式
Cadence招聘Principal/Lead ApplicationEngineer -数字前端
Title: Principal/LeadApplication Engineer -数字前端
Location SH
更多职位信息敬请关注Cadence公众微信平台:Cadence微招聘
If you haveinterest, PLS send your update CV to job_china@cadence.com
Position Description:
1. To provide key technicalsupport in digital IC design implementation, product demonstration, and salespresentations.
2. To demonstrate strongability and to be hands-on in RTL-to-GDSII design methodology, including bothchallenging low power and high performance designs.
3. Have real designexperience including synthesis, STA, formal check, DFT, have deepknowledge of low power design concept, CPF/UPF format
4. Assist in technicalevaluation, assessment and delivery of concurrent ASIC/SoC designs.
5. To play a leading roleamong other team members, while receive little instruction on routine andgeneral assignments.
Position Requirements:
1. A bachelor's degree isessential and 3+ years’ experience in IC design, electronic engineering orcomputer science applications.
2. Ability to understand andarticulate technical issues, (and knowledge of) design products and theirapplications.
3. Requires working knowledgeof one or more programming languages, and effective communication and softskills.
4. An MS degree and/orworking experience in multi-nation IC design house is a plus.
GMT+8, 2025-10-4 04:23 , Processed in 0.010188 second(s), 4 queries , Gzip On, Redis On.
