查看: 1793|回复: 0
Some errors when install ADS 2016.01 for linux
发表于 2017-7-20 21:44:54 | 显示全部楼层 |阅读模式
When i install ADS 2016 for linux to my computer using the crack in this forum, i met some error when patching the program by pubkey_verify,
./lib/linux_x86_64/libcublas.so.6.5.14atch point found! addr=00215EA0
./lib/linux_x86_64/libcublas.soatch point found! addr=00215EA0
./adsptolemy/lib.linux_x86_64/libsdfstars.so:--------------------Found function head--------------------------548141
./adsptolemy/lib.linux_x86_64/libsdfstars.so: Patch point not found!
          00085486 08 9A 01 00 00 0A            or [rdx+0xa000001], bl
          0008548C 26 41 01 00                  add [es:r8], eax
          00085490 00 38                        add [rax], bh
          00085492 04 03                        add al, 0x3
          00085494 08 6F 03                     or [rdi+0x3], ch
          00085497 00 00                        add [rax], al
          00085499 0A 27                        or ah, [rdi]
          0008549B C0 25 00 00 40 04 03         shl [rip+0x4400000], 0x3
          000854A2 14 57                        adc al, 0x57
          000854A4 17                           db 0x17
          000854A5 00 00                        add [rax], al
          000854A7 20 01                        and [rcx], al
          000854A9 15 1E 04 00 00               adc eax, 0x41e
          000854AE B9 25 00 00 0B               mov ecx, 0xb000025
          000854B3 64 AD                        lodsd
          000854B5 00 00                        add [rax], al
          000854B7 00 00                        add [rax], al
          000854B9 03 08                        add ecx, [rax]
          000854BB 05 25 12 00 00               add eax, 0x1225
          000854C0 11 99 83 00 00 F0            adc [rcx-0xfffff7d], ebx
          000854C6 06                           db 0x6
          000854C7 21 01                        and [rcx], eax
          000854C9 14 0C                        adc al, 0xc
          000854CB 03 00                        add eax, [rax]
          000854CD 00 5C 26 00                  add [rsi+0x0], bl
          000854D1 00 06                        add [rsi], al
          000854D3 61                           db 0x61
          000854D4 18 00                        sbb [rax], al
          000854D6 00 00                        add [rax], al
          000854D8 12 7F 00                     adc bh, [rdi+0x0]
          000854DB 00 00                        add [rax], al
          000854DD 21 01                        and [rcx], eax
          000854DF 1C FD                        sbb al, 0xfd
          000854E1 02 00                        add al, [rax]
          000854E3 00 60 01                     add [rax+0x1], ah
          000854E6 13 B2 58 00 00 21            adc esi, [rdx+0x21000058]
          000854EC 01 20                        add [rax], esp
          000854EE 02 03                        add al, [rbx]
          000854F0 00 00                        add [rax], al
          000854F2 20 02                        and [rdx], al
          000854F4 02 13                        add dl, [rbx]
          000854F6 BC 04 00 00 21               mov esp, 0x21000004
          000854FB 01 21                        add [rcx], esp
          000854FD 5C                           pop rsp
          000854FE 26 00 00                     add [es:rax], al
          00085501 B8 02 02 13 21               mov eax, 0x21130202
          00085506 1A 00                        sbb al, [rax]
          00085508 00 21                        add [rcx], ah
          0008550A 01 22                        add [rdx], esp
          0008550C 5C                           pop rsp
          0008550D 26 00 00                     add [es:rax], al
          00085510 78 04                        js 0x90
          00085512 02 13                        add dl, [rbx]
          00085514 D9                           invalid
          00085515 0D 00 00 21 01               or eax, 0x1210000
          0008551A 23 07                        and eax, [rdi]
          0008551C 03 00                        add eax, [rax]
          0008551E 00 38                        add [rax], bh
          00085520 06                           db 0x6
          00085521 02 09                        add cl, [rcx]./lib/linux_x86_64/libcublas.so.6.5.14atch point found! addr=00215EA0
./lib/linux_x86_64/libcublas.so:Patch point found! addr=00215EA0
          000854A4 17                           db 0x17
          000854C6 06                           db 0x6
          000854D3 61                           db 0x61
          000854FD 5C                           pop rsp
          0008550C 5C                           pop rsp
          00085514 D9                           invalid
          00085520 06                           db 0x6
          00085523 70 6F                        jo 0x10e
          00085525 73 00                        jae 0xa1
          00085527 09 49 29                     or [rcx+0x29], ecx
          0008552A 00 00                        add [rax], al
          0008552C 00 C8                        add al, cl
          0008552E 06                           db 0x6
          0008552F 02 08                        add cl, [rax]
          00085531 0E                           db 0xe
          00085532 0D 00 00 09 4A               or eax, 0x4a090000
          00085537 61                           db 0x61
          00085538 26 00 00                     add [es:rax], al
          0008553B D0 06                        rol [rsi], 1
          0008553D 02 14 57                     add dl, [rdi+rdx*2]
          00085540 17                           db 0x17
          00085541 00 00                        add [rax], al
          00085543 22 01                        and al, [rcx]
          00085545 15 D7 0A 00 00               adc eax, 0xad7
          0008554A 55                           push rbp
          0008554B 26 00 00                     add [es:rax], al
          0008552E 06                           db 0x6
          00085531 0E                           db 0xe
          00085537 61                           db 0x61
          00085540 17                           db 0x17
GMT+8, 2025-12-19 18:56 , Processed in 0.016176 second(s), 4 queries , Gzip On, Redis On.
