查看: 2678|回复: 4
[求助] help on DFT flow
发表于 2017-6-29 09:57:21 | 显示全部楼层 |阅读模式
need help
I using DFT labs DFTCompilerêμÑéÅàÑμ×êáÏ
the lab have two flows unmapped and mapped
I did run them both. According to lab instruction *Lab.pdf
all the D* violations would be fixed when I run set_dft_insertion_configureation and set_autofix_configuration
in one the *.tcl, settings_insert_dft.tcl
I noticed that I am getting the followings:
warning: Violations occurred during test design rule checking. (TEST-124)
Information: Test design rule checking completed. (TEST-123)
Warning: Clock information for all sequential cells of design is missing.  (TEST-374)
  Architecting Scan Chains
Warning: Scan chain 'chain0' has zero elements. (TEST-352)
Warning: Scan chain 'chain1' has zero elements. (TEST-352)
Warning: Scan chain 'chain2' has zero elements. (TEST-352)
Warning: Scan chain 'chain3' has zero elements. (TEST-352)
Warning: Scan chain 'chain4' has zero elements. (TEST-352)
Warning: Scan chain 'chain5' has zero elements. (TEST-352)
and all the D* violations are still there.
please help,
I did check the clock, pclk to those in D1 violations:
I have the following in settings_protocol.tcl
set_dft_signal -view existing_dft -type ScanClock -timing {45 55} -port {pclk sdr_clk sys_clk}
 楼主| 发表于 2017-6-29 11:20:57 | 显示全部楼层
回复 1# xiaoyisimonguo
   please help
 楼主| 发表于 2017-6-30 07:01:51 | 显示全部楼层
need help
 楼主| 发表于 2017-6-30 14:02:59 | 显示全部楼层
   any one could help?
发表于 2020-7-2 11:20:29 | 显示全部楼层
请问这个问题怎么解决的?
GMT+8, 2025-12-26 10:57 , Processed in 0.014198 second(s), 3 queries , Gzip On, Redis On.
