查看: 8649|回复: 11
[原创] 中的一篇文章 ESSCIRC 2017 - Low Flicker Noise Corner Oscillator
发表于 2017-6-26 18:43:25 | 显示全部楼层 |阅读模式
A 30-GHz Class-F23 Oscillator in 28nm CMOS Using Harmonic Extraction and Achieving 120 kHz 1/f3 Corner
Yizhe Hu, Teerachot Siriburanon, R. Bogdan Staszewski
欢迎版内朋友们去听
Session Code: A4L-C
Date & Time: Tuesday September 12, 2017 (14:00 - 15:20)
Chair: Jaehyouk Choi, Kenichi Okada
08094532-2.pdf (1.5 MB , 下载次数: 133 )
 楼主| 发表于 2017-6-26 18:44:18 | 显示全部楼层
回复 1# JoyShockley
Abstract
This paper presents a mmW frequency generation stage aimed at minimizing phase noise via waveform shaping and harmonic extraction while preventing flicker noise from upconversion via proper harmonic terminations. A second-harmonic tank resonance is assisted by a proposed embedded decoupling capacitor inside a transformer for shortest and well controlled common-mode current return path. Class-F operation with third-harmonic boosting and extraction techniques allow to maintain high quality factor of a 10 GHz tank at the 30 GHz frequency generation while providing implicit divide-by-3 functionality. The proposed 27.3-31.2 GHz oscillator is implemented in 28-nm CMOS. It achieves phase noise of -106 dBc/Hz at 1-MHz offset and figure-of-merit (FoM) of -184 dB at 27.3GHz. Its flicker phase-noise corner of 120 kHz is an order-of-magnitude better than currently achieved at mmW.
发表于 2017-6-27 10:13:50 | 显示全部楼层
在哪里?
 楼主| 发表于 2017-6-27 18:26:10 | 显示全部楼层
回复 3# waveguides
    比利时鲁汶
发表于 2017-6-28 10:46:38 | 显示全部楼层
(__)
/oo\\________
  \\_|___\\_|/  *
    ||  YY|
发表于 2017-9-14 05:10:42 | 显示全部楼层
回复 1# JoyShockley
   楼主可以分享下 ESSCIRC 2017的全部文章吗,谢谢
 楼主| 发表于 2017-11-16 20:12:27 | 显示全部楼层
回复 1# JoyShockley
    论文已经发布啦
发表于 2017-11-21 10:12:40 | 显示全部楼层
thanks
发表于 2018-9-5 15:25:06 | 显示全部楼层
thanks for sharing
发表于 2021-10-9 00:02:41 | 显示全部楼层
Thanks!!!
GMT+8, 2025-12-30 23:02 , Processed in 0.018835 second(s), 3 queries , Gzip On, Redis On.
