查看: 2813|回复: 6
RF Paper:a 2.7V GSM RF transceiver IC
发表于 2007-6-16 04:39:16 | 显示全部楼层 |阅读模式
Abstract—A 2.7-V RF transceiver IC is intended for small, lowcost
global system for mobile communications (GSM) handsets.
This chip includes a quadrature modulator (QMOD) and an
offset phase locked loop (OPLL) in the transmit path and a dual
IF receiver that consists of a low noise amplifier (LNA) with
an active-bias circuit, two Gilbert-cell mixers, a programmable
gain linear amplifier (PGA), and a quadrature demodulator
(QDEM). The IC also contains frequency dividers with a very
high frequency voltage controlled oscillator (VHF-VCO) to simplify
the receiver design. The system evaluation results are the
phase error of 2.7 rms and the noise transmitted in the GSM
receiving band of 􀀀163 dBc/Hz for transmitters and the reference
sensitivity of 􀀀105 dBm for receivers. Power-control functions are
provided for independent transmit and receive operation. The IC
is implemented by using bipolar technology with fT = 15 GHz,
rbb = 150 , and 0.6-m features.
a 2.7V GSM RF transceiver IC.pdf
192.22 KB, 下载次数: 95 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-6-16 22:57:01 | 显示全部楼层
ding!!!
发表于 2007-6-22 09:07:39 | 显示全部楼层
ding !
发表于 2008-12-20 11:17:46 | 显示全部楼层
thansk
谢谢分享
发表于 2011-7-31 17:26:25 | 显示全部楼层
下来学习
发表于 2012-6-21 13:23:10 | 显示全部楼层
1997年的论文,有点老,不过还是谢谢!
发表于 2014-7-31 00:39:14 | 显示全部楼层
顶楼主
GMT+8, 2025-12-27 02:16 , Processed in 0.021650 second(s), 7 queries , Gzip On, Redis On.
