查看: 6539|回复: 17
[资料] Make Your Own PCBs with EAGLE: From Schematic Designs to Finished Boards
发表于 2017-6-14 14:23:51 | 显示全部楼层 |阅读模式
非常适合初学者的一本书,讲述了如何从电路原理图到PCB的做法。
Design custom printed circuit boards with EAGLE
Learn how to make double-sided professional-quality PCBs from the ground up using EAGLE--the powerful, flexible design software. In this step-by-step guide, electronics guru Simon Monk leads you through the process of designing a schematic, transforming it into a PCB layout, and submitting standard Gerber files to a manufacturing service to create your finished board. Filled with detailed illustrations, photos, and screenshots, Make Your Own PCBs with EAGLE features downloadable example projects so you can get started right away.
  • Install EAGLE Light Edition and discover the views and screens that make up an EAGLE project
  • Create the schematic and board files for a simple LED project
  • Find the right components and libraries for your projects
  • Work with the Schematic Editor
  • Lay out PCBs with through-hole components and with surface mount technology
  • Build a sound level meter with a small amplifier and ten LEDs
  • Generate Gerber design files to submit for fabrication
  • Solder through-hole PCBs and SMD boards
  • Design a plug-in Arduino shield
  • Build a Raspberry Pi expansion board
  • Automate repetitive tasks using scripts and User Language Programs
  • Create your own libraries and parts and modify existing components
MakeyourownPCBswithEAGLEfromschematicdesignstofinishedboard.part1.rar
15 MB, 下载次数: 78 , 下载积分: 资产 -5 信元, 下载支出 5 信元
MakeyourownPCBswithEAGLEfromschematicdesignstofinishedboard.part2.rar
4.1 MB, 下载次数: 53 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2017-6-25 19:24:43 | 显示全部楼层
thanks for sharing
发表于 2017-6-26 00:39:37 | 显示全部楼层
Make you rown PCBs with EAGLE from schematic designs to finished board
发表于 2017-6-29 09:11:30 | 显示全部楼层
价格有点高啊
发表于 2017-7-4 17:31:58 | 显示全部楼层
thanks thanks
发表于 2017-7-10 22:51:21 | 显示全部楼层
谢谢,是2017版吗?
发表于 2017-7-10 22:52:59 | 显示全部楼层
试试看.新版的针对7.7版本吧
发表于 2017-7-11 16:05:53 | 显示全部楼层
支持了 是cadence 的最好了
发表于 2017-11-4 19:34:05 | 显示全部楼层
Vota a todos los participantes
发表于 2017-11-12 00:13:19 | 显示全部楼层
回复 1# underrealler
        thanks for sharing
GMT+8, 2025-11-2 09:44 , Processed in 0.521631 second(s), 5 queries , Gzip On, Redis On.
