查看: 2714|回复: 1
[求助] ic614 in centOS machine, please help
发表于 2017-6-13 08:13:22 | 显示全部楼层 |阅读模式
successfully installed in a centOS machine, but I still could not run virtuoso
please help, see below
virtuoso &
[2] 3545
[1]    Exit 1                        viruoso
codelion-ic6141 61 > ERROR: Could not find Cadence installation root for
/home/tools/cadence/ic06.14/tools/bin/cdsGetOABinPath
Make sure that cdsGetOABinPath is part of the Cadence installation.
virtuoso:   ERROR: No proper OA2.2 installation found. Fix the errors reported by cdsGetOABinPath.
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
发表于 2017-6-13 10:52:01 | 显示全部楼层
be sure that you have installed OA staff in your tools directory, then setup  OA_HOME to correct dir.
GMT+8, 2025-12-26 20:28 , Processed in 0.178327 second(s), 4 queries , Gzip On, Redis On.
