查看: 2254|回复: 1
[求助] 请教 8051+模拟ic cadence数模混合的问题
发表于 2017-6-7 09:42:32 | 显示全部楼层 |阅读模式
各位好,最近在做 8051+模拟ic 数模混合,用cadence 数模混合仿真平台,将8051各个模块的verilong代码都做成functional,但是有报错。
我定义了参数表并include了`include "./mcu_package.inc"
mcu_package.inc参数表里面部分内容:
// cycle definitions:
`define c1 2'b00
`define c2 2'b01
`define c3 2'b10
`define c4 2'b11
代码里面部分内容:
case (bus_seq )
          // instruction read:
          `instr_rd_seq :
          begin
            case (cycle )
              `c1 : begin
                      if (ext_rom_access == 1)
                      begin
                        p0_mem_reg_n   <= 1;
// p0 output is address
                        p0_addr_data_n <= 1;
                        p2_mem_reg_n   <= 1;
// for whole sequence
                        ale_pos        <= 0;
// start ale cycle
                      end
                      else
但是很多`C1之类的报错:
ncvlog: *E,NOTSTT (/home/user2/8051/rtl/8051/mcu_biu/functional/verilog.v,414|20): expecting a statement [9(IEEE)].
(`define macro: rd_rom_seq [/home/user2/8051/rtl/8051/mcu_biu/functional/verilog.v line 145], file: /home/user2/8051/rtl/8051/mcu_biu/functional/verilog.v line 414)
              `c1 : begin
应该是定义的参数没有正常识别,向大家请教,是cadence verilong不支持inlude 参数表?还是其他问题?如何修改?
发表于 2018-11-19 14:56:46 | 显示全部楼层
感謝大大無私分享
GMT+8, 2025-12-17 00:44 , Processed in 0.011814 second(s), 4 queries , Gzip On, Redis On.
