查看: 2204|回复: 1
[求助] design compiler in topographical mode
发表于 2017-6-6 08:30:07 | 显示全部楼层 |阅读模式
from the man page, I could see that set_tlu_plu_files only in topographical mode:
set_tlu_plus_files
              Sets  the  files  used  for TLUPlus extraction.  This command is
              supported only in topographical mode.
But how do set it up to run "in topographical mode"?
please help
I am running Design Vision, L-2016.03-SP1 version --Apr 18, 2016
发表于 2017-10-7 21:03:53 | 显示全部楼层
回复 1# xiaoyisimonguo
   When you open the Design Compiler, you can use the command:design_vision -topographical_mode -gui
GMT+8, 2025-12-24 22:15 , Processed in 0.012170 second(s), 4 queries , Gzip On, Redis On.
