查看: 2803|回复: 7
[求助] help to run virtuoso
发表于 2017-6-2 12:38:06 | 显示全部楼层 |阅读模式
I could see virtuoso with
which virtuoso:
   /tools/cadence/IC06.14.005/tools/dfII/bin/virtuoso
but when I type in
virtuoso
I got
"virtuoso: Command not found."
and the virtuoso is:
lrwxrwxrwx. 1 dubeeloo dubeeloo 39 May 18 17:32 /tools/cadence/IC06.14.005/tools/dfII/bin/virtuoso -> ../../../share/bin/cdnWrapperWithOA2009
please help
发表于 2017-6-2 13:23:10 | 显示全部楼层
回复 1# xiaoyisimonguo
   环境变量没有设置
发表于 2017-6-2 23:10:20 | 显示全部楼层
打造“virtuoso”的完整路径。 如果仍然没有运行,请检查变量
 楼主| 发表于 2017-6-3 01:53:32 | 显示全部楼层
回复 2# populbb
   thank you, populbb, for the reply
Could you please specify which env variable?
I have the follow defined:
CDS_LMD=/home/tools/cadence/flexm10.8.0.7
CDS_TOOLS=/home/tools/cadence/IC06.14.005/tools/dfII/bin
CDSDIR=/home/tools/cadence/IC06.14.005
CDSHOME=/home/tools/cadence/IC06.14.005
CDS_SPECTRERF_FBENABLE=1
CDS_Netlisting_Mode=Analog
CDS_ROOT=/home/tools/cadence/IC06.14.005
CDS_AUTO_64BIT=ALL
CDS_INST_DIR=/home/tools/cadence/IC06.14.005
 楼主| 发表于 2017-6-3 02:08:30 | 显示全部楼层
回复 3# dotana
   thank you, dotana, for the inquiry
I did try to use absolute path:
/home/tools/cadence/IC06.14.005/tools/dfII/bin/virtuoso
/home/tools/cadence/IC06.14.005/tools/dfII/bin/virtuoso: Command not found.
it is very mis-leading:
I could see it:
ls -l /home/tools/cadence/IC06.14.005/tools/dfII/bin/virtuoso
lrwxrwxrwx. 1 dubeeloo dubeeloo 39 May 18 17:32 /home/tools/cadence/IC06.14.005/tools/dfII/bin/virtuoso -> ../../../share/bin/cdnWrapperWithOA2009
and I could tell it has the right permission
发表于 2017-6-3 13:54:08 | 显示全部楼层
回复 5# xiaoyisimonguo
    你要检查它指向的 ../../../share/bin/cdnWrapperWithOA2009 存在不存在啊!
发表于 2017-6-3 13:55:25 | 显示全部楼层
这个议题发错板块了,赶快移到模拟IC设计板块去吧。
发表于 2017-6-6 13:22:18 | 显示全部楼层
环境变量还要source一下,才能生效
GMT+8, 2025-12-26 20:26 , Processed in 0.015879 second(s), 3 queries , Gzip On, Redis On.
