查看: 3436|回复: 9
[求助] ncsim 仿真无故停止
发表于 2017-5-9 15:10:35 | 显示全部楼层 |阅读模式
在 ncsim仿真时,到某个时刻,进程就死掉进入 sleep状态,这是怎么回事?求大侠解惑
发表于 2017-5-9 16:45:53 | 显示全部楼层
進入Sleep? 是指 時間軸不跑了嗎?
一般狀況應該是有combination loop
 楼主| 发表于 2019-1-10 19:13:18 | 显示全部楼层
回复 2# wythelin
是的,还没跑完,进程就消失不见了,不再跑了.现在又出现这个问题了
 楼主| 发表于 2019-1-10 19:14:08 | 显示全部楼层
又出现这个问题了,有人碰到过这个情况吗,求解啊?会不会是软件问题,没破解好?
 楼主| 发表于 2019-1-10 19:33:03 | 显示全部楼层
回复 2# wythelin
combination loop  是什么意思,要怎么解决
发表于 2019-1-11 13:18:03 | 显示全部楼层
看一下是不是有zero delay回路
 楼主| 发表于 2019-1-11 13:48:25 | 显示全部楼层
回复 6# 547925053
   谢谢你啊,能说具体点怎么检查吗?
发表于 2019-1-11 15:50:24 | 显示全部楼层
我理解错了,应该是combinational loop,Combinational loops are among the most common causes of instability and unreliability in digital designs. They should be avoided whenever possible. In a synchronous design, feedback loops should include registers. Combinational loops generally violate synchronous design principles by establishing a direct feedback loop that contains no registers. For example, a combinational loop occurs when the left-hand side of an arithmetic expression also appears on the right-hand side in HDL code. A combinational loop also occurs when you feed back the output of a register to an asynchronous pin of the same register through combinational logic。
发表于 2019-1-11 15:50:57 | 显示全部楼层
回复 7# lccchc
我理解错了,应该是combinational loop:
   Combinational loops are among the most common causes of instability and unreliability in digital designs. They should be avoided whenever possible. In a synchronous design, feedback loops should include registers. Combinational loops generally violate synchronous design principles by establishing a direct feedback loop that contains no registers. For example, a combinational loop occurs when the left-hand side of an arithmetic expression also appears on the right-hand side in HDL code. A combinational loop also occurs when you feed back the output of a register to an asynchronous pin of the same register through combinational logic,
发表于 2019-1-11 16:02:24 | 显示全部楼层
GMT+8, 2025-10-13 01:54 , Processed in 0.021640 second(s), 4 queries , Gzip On, Redis On.
