查看: 5090|回复: 3
[求助] Virtuoso AMS混仿导入Schematic后Failed to Simulate的问题
发表于 2017-4-15 09:39:27 | 显示全部楼层 |阅读模式
版上的各位大大们好,小弟初来乍到。最近在做一个SAR ADC的仿真,先是用的Verilog-a跑的仿真,到这里都一切正常。然后确认function没有问题了之后,我尝试把其中几个block换成schematic的再仿。我有更新ams的library list,也有重新配置我的config,摁下“RUN”之后,netlist generate没问题,Compile没问题,Elaboration也没问题,然后就报“Failed to Simulate”了,Log文件里也没提及具体是什么问题。我把log file粘到下边了。如有哪位大大知道可能是什么原因造成的问题,还望不吝赐教。先行谢过了!
Log File:
module SAR_ADC_Veriloga.sha:veriloga (up-to-date)
errors: 0, warnings: 0
ncvlog: Memory Usage - 9.7M program + 19.3M data = 29.0M total
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 92.1% cpu)
Successfully compiled ('SAR_ADC_Veriloga' 'sha' 'veriloga').
ncvlog(64): 08.20-s019: (c) Copyright 1995-2009 Cadence Design Systems, Inc.
file: /home/eng/j/jxf141030/gf65lpe/SAR_ADC_Veriloga/combine_test/schematic/verilog.vams
module SAR_ADC_Veriloga.combine_test:schematic (up-to-date)
ncvlog: Memory Usage - 9.7M program + 19.3M data = 28.9M total
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.1s, 38.9% cpu)
Successfully compiled ('SAR_ADC_Veriloga' 'combine_test' 'schematic').
Compilation successful.
ncelab(64): 08.20-s019: (c) Copyright 1995-2009 Cadence Design Systems, Inc.
Elaborating the design hierarchy:
ncelab: *N,SFEDPL: Deploying new SFE in analog engine.
"/proj/cad/library/mosis/GF65_LPe/EDA-CAD-65N-DK012_rev3/ch65lpe_alt_DK012_OA_Rev3/6_00_01_00_LB/ch65lpe_alt/../models/YI-SM00034/1C/sm00034-1c.scs", line 39:
Illegal library definition found in netlist
Discipline resolution Pass...
Building instance overlay tables: .................... Done
Loading native compiled code:     .................... Done
Building instance specific data structures.
Design hierarchy summary:
                 Instances  Unique
Modules:                26       9
Registers:              30      10
Scalar wires:           13       -
Expanded wires:          8       1
Vectored wires:          4       -
Always blocks:          29       9
Initial blocks:         12       2
Cont. assignments:      11       3
Interconnect:           33       -
Simulation timescale:  1ps
Equivalent connect instance summary:
1: combine_test.I17
2: combine_test.I13
3: combine_test.I12
4: combine_test.I11
5: combine_test.I10
6: combine_test.I9
7: combine_test.I8
8: combine_test.I7
9: combine_test.I6
10: combine_test.I16
11: combine_test.I15
12: combine_test.I14
Writing initial simulation snapshot: SAR_ADC_Veriloga.combine_test:config
Elaborating analog portion of the design hierarchy:
libsyracuse:  @(#)$CDS: libsyracuse version   11/15/2009 22:11 (chfclx007) $(sub-version  1115  )
ncelab: Memory Usage - 24.1M program + 756.2M data = 780.3M total
ncelab: CPU Usage - 0.3s system + 1.3s user = 1.6s total (3.9s, 40.4% cpu)
Successfully elaborated ("SAR_ADC_Veriloga" "combine_test" "config").
ncsim(64): 08.20-s019: (c) Copyright 1995-2009 Cadence Design Systems, Inc.
Failed to simulate ("SAR_ADC_Veriloga" "combine_test" "config").
txe(64): 08.20-s019: (c) Copyright 1995-2008 Cadence Design Systems, Inc.
 楼主| 发表于 2017-4-26 04:50:19 | 显示全部楼层
要把所有仿真的模块放到同一Lib下就没问题了...分开几个Library哪怕在cell bingings里都设置好也是无法仿真的...也不报个错...
回复 支持 2 反对 0
发表于 2019-2-27 18:36:11 | 显示全部楼层
你好,楼主,最近我在学习virtuoso 6.1.7的Verilog-A仿真,在写完Verilog-A代码后,check时一直报warrning,后面仿真也无法继续,请问有遇到过这种问题吗
发表于 2020-6-21 12:45:52 | 显示全部楼层
学习中
GMT+8, 2025-12-25 11:50 , Processed in 0.016816 second(s), 4 queries , Gzip On, Redis On.
