查看: 4480|回复: 5
求助!在启动Iscape04.23时报错
发表于 2017-4-13 15:07:43 | 显示全部楼层 |阅读模式
这个怎么解决?
Initializing InstallScape using JVM at /usr/bin/java. This might take some time...
Error: Invalid or corrupt jarfile /opt/cadence/installscape/iscape.04.23-s010/lib/InstallScape.jar
Failed with InstallScape JVM.
Now loading System JVM...
Error:
/usr/bin/java
Could not use JVM packaged with Installcape. The Java in your path did not work or could not find Java in your path.  Ensure that Java 1.6 or later is in your PATH environment variable and restart InstallScape.
发表于 2017-4-13 20:07:56 | 显示全部楼层
看错误信息,似乎是没安装JAVA JRE吧。或者JAVA版本不兼容。
发表于 2019-8-2 02:56:45 | 显示全部楼层
楼主解决了么 遇到同样问题了
发表于 2020-1-30 20:08:19 | 显示全部楼层
这个最后如何解决的呢楼主???
发表于 2020-3-2 12:27:12 | 显示全部楼层
楼主你这个是怎么解决的,想问问,我现在也遇到了这个问题
发表于 2021-8-21 14:07:45 | 显示全部楼层
楼主,这个问题,解决了吗?怎么解决的?
GMT+8, 2025-12-25 14:49 , Processed in 0.017417 second(s), 5 queries , Gzip On, Redis On.
