楼主: xiaohe8696
关闭主题
发表于 2017-11-21 16:18:42 | 显示全部楼层
试一下看看
发表于 2017-11-24 19:55:41 | 显示全部楼层
thanks a lot!
发表于 2017-11-29 13:34:11 | 显示全部楼层
thanks~
发表于 2017-11-30 21:36:42 | 显示全部楼层
thanks
发表于 2017-12-4 01:53:49 | 显示全部楼层
Thank you.
发表于 2017-12-4 03:52:12 | 显示全部楼层
http://pan.baidu.com/s/1nuSxrgX
gjtv
发表于 2017-12-4 03:52:45 | 显示全部楼层
gjtv
发表于 2017-12-4 03:54:24 | 显示全部楼层
code is:
gjtv
发表于 2017-12-4 13:11:43 | 显示全部楼层
thanks
发表于 2017-12-6 15:37:25 | 显示全部楼层
多谢,就在找这个。
但是,laker-2015.12-2 用不了,说产生的license 的版本比软件要老。
*ERROR* License checking failed. It may be caused by the maximum number of licensed users has been reached, or the license version is older than the software version. Use laker -licdebug for more information.
[SCL] 12/06/2017 15:47:39 PID:6371 Client:localhost.localdomain Authorization failed Laker_L3 2015.12
[SCL] 12/06/2017 15:47:39 PID:6371 Client:localhost.localdomain Authorization failed Laker_L2 2015.12
[SCL] 12/06/2017 15:47:39 PID:6371 Client:localhost.localdomain Authorization failed Laker_FPD_L2 2015.12
[SCL] 12/06/2017 15:47:39 PID:6371 Client:localhost.localdomain Authorization failed Laker_FPD 2015.12
[SCL] 12/06/2017 15:47:39 PID:6371 Client:localhost.localdomain Authorization failed Laker_L1 2015.12
[SCL] 12/06/2017 15:47:39 PID:6371 Client:localhost.localdomain Authorization failed nLayout 2015.12
[SCL] 12/06/2017 15:47:39 PID:6371 Client:localhost.localdomain Authorization failed Laker_Viewer 2015.12
[SCL] 12/06/2017 15:47:39 PID:6371 Client:localhost.localdomain Authorization failed Laker_T1 2015.12
[SCL] 12/06/2017 15:47:39 PID:6371 Client:localhost.localdomain Authorization failed Laker_T1_TLM 2015.12
[SCL] 12/06/2017 15:47:39 PID:6371 Client:localhost.localdomain Authorization failed T1_TLM 2015.12
GMT+8, 2025-10-19 07:49 , Processed in 0.018453 second(s), 3 queries , Gzip On, Redis On.
