查看: 7397|回复: 22
LDO IEEE论文合集part
发表于 2007-6-14 18:39:16 | 显示全部楼层 |阅读模式
LDO IEEE论文合集
我手上有许多LDO的资料,大约几百兆,发不完,有需要的朋友请留个联系方式吧
A 150mA Low Noise, High PSRR Low-Dropout.pdf
A Capacitor-Free CMOS Low-Dropout Regulator.pdf
A Current-Mode DC-DC Buck Converter with High Stability Independent of Load and Supply Voltage.pdf
A frequency compensation scheme for LDO voltage regulators.pdf
A Linear LDO Regulator with Modified NMCF Frequency Compensation Independent of Off-chip Capacitor and ESR.pdf
A Low Dropout, CMOS Regulator with High PSR over Wideband Frequencies.pdf
A Low Noise, High Power Supply Rejection Low Dropout Regulator for Wireless System-on-Chip Applications.pdf
A Low-dropout Regulator with Unconditional.pdf
A Low-Noise Low-Drift Transducer ADC.pdf
A low-voltage, low quiescent current, low drop-out regulator.pdf
a multi-mode ldo-based .pdf
A Power Efficient and Fast Transient Response Low Drop-Out Regulator in Standard CMOS Process.pdf
A robust frequency compensation scheme for ldo regulators.pdf
All CMOS Low Drop-Out Regulator with Large Supply Currents for System using Li-ion Battery.pdf
Analysis and design of monolithic,High PSR, Linear Regulators for soc applications.pdf
Analysis and Design of Voltage Controlled Current Source for LDO Frequency Compensation.pdf
Analysis of low-dropout regulator topologies for low-voltage regulation.pdf
发表于 2007-6-14 19:20:26 | 显示全部楼层
谢谢!支持,鼓励。楼主挑好的上传吧!
 楼主| 发表于 2007-6-14 19:55:14 | 显示全部楼层
谢谢鼓励,初次发帖就有人鼓励,谢谢
发表于 2007-7-3 18:58:19 | 显示全部楼层
谢谢楼主
有空就下点看看
发表于 2007-11-6 22:58:48 | 显示全部楼层
LDO IEEE论文合集part
哈哈,麻烦楼主了,我的mail:husiming07@126.com
发表于 2007-11-7 02:26:55 | 显示全部楼层
thanks for your information...............
thanks..............
发表于 2008-2-20 15:35:12 | 显示全部楼层
麻烦楼主,fmh01@163.com
发表于 2008-10-9 10:50:58 | 显示全部楼层
顶顶顶顶顶顶
发表于 2009-9-4 20:13:09 | 显示全部楼层
非常感谢楼主,开学制定培养计划正需要其中的论文,能给我发下吗?非常感谢!yeshengnuist@163.com
发表于 2009-9-17 22:48:19 | 显示全部楼层
dfdfdfdfdfdfdf
GMT+8, 2025-12-26 14:15 , Processed in 0.038305 second(s), 6 queries , Gzip On, Redis On.
