查看: 3036|回复: 1
[求助] IC617 spectre仿真问题(新版.def文件需要用verilog-A文件代替问题)
发表于 2017-3-21 11:15:43 | 显示全部楼层 |阅读模式
各位大大,我在运行电路原理图仿真时,出现以下错误,求解决!!
Fatal error found byspectre during AHDL read-in.
         FATAL (VACOMP-2096): File ‘/home/kx/Myproject/kx_test2/smic13mmrf__1225_1P8M_2000605271040/models/spectre/res_rf.def’ does not appear to be a vaild Verilog-Afile. In previous release, ‘.def’ was a file extension typically used forSpectreHDL files but SpectreHDL is no longer supported. If this file isSpectreHDL file. You need to replaced it with an equivalent Verilog-A file.
请问这种解决办法是使用verilog-A文件更换.def文件吗?如果是求哪位大大发我一个verilog-A文件,跪求。如果不是,需要怎么修改呢?
发表于 2020-11-9 19:35:19 | 显示全部楼层
同秋
GMT+8, 2025-12-29 13:37 , Processed in 0.012308 second(s), 4 queries , Gzip On, Redis On.
