查看: 2734|回复: 2
[原创] 带隙运放输出到vdd的电容、电阻是什么作用?
发表于 2017-3-20 21:30:33 | 显示全部楼层 |阅读模式
悬赏100资产未解决
发表于 2017-3-20 22:30:54 | 显示全部楼层
It is possible to add zero poles at the output of the op amp .....
Turn the high-frequency op amp output noise to VDD. While leaving the low frequency (DC) alone.
Is your Op-Amp a single level?
The picture is not clear. The picture has no resolution to read the name of the node.
Where is the BG output (picture chopping)?
 楼主| 发表于 2017-3-21 16:00:04 | 显示全部楼层
GMT+8, 2025-12-17 12:03 , Processed in 0.226727 second(s), 5 queries , Gzip On, Redis On.
