查看: 2423|回复: 1
[招聘] 【招聘】美光上海招聘资深电路设计工程师/验证工程师
发表于 2017-3-10 21:46:15 | 显示全部楼层 |阅读模式
美光半导体(Micron)招聘资深电路设计工程师/验证工程师
Senior DRAM Design Engineer
Workplace: China, Shanghai
Resume to : cindyling@micron.com/maxma@micron.com
Description
As a Senior Design Engineer in DRAM Engineering Group (DEG) at MicronTechnology, Inc., you will be responsible for using the state of art technologyto design and verify mix signal circuitry used in the cutting-edge memoryproducts. In this position
You will be challenged by the complexity anddifficulty of designing and verifying the high density memory chip (up to 8Gb)with huge scale of circuit capability (over 4M transistors), ultra high speed(clock cycle is less than 1ns), complicated functionality (DDR4, LPDDR4),advanced low power and power management technology.
  • You will     work closely with Micron's various design teams all over the world to     contribute to the success of the design.
  • You may need     to travel to Japan and U.S. in short term for technical communication,     project support.
  • You will     work and support the efforts of groups such as Product Engineering, Test,     Probe, Process Integration, Assembly and Marketing to proactively design     products that optimize all manufacturing functions and assure the best     cost, quality, reliability, time-to-market, and customer satisfaction.
Responsibilities
Contribute to the development of new DRAMproducts by assisting with the overall conception, architecture evaluation,circuit design, verification and optimization.
In charge of designing and verifying newcircuitry (digital/analog) used in the Memory product according to designrequirements.
Parasitic modeling and assisting in designvalidation, reticle experiments and required tape-out revisions.
Oversee and manage the layout processincluding floor-planning, placement, and routing
Perform verification processes with modelingand simulation using industry standard simulators
Maintain technical expertise and providetraining
Work with Marketing, Probe, Assembly, Test,Process Integration, and Product Engineering groups to ensure propermanufacturability of product
Proactively seek inputs from Standards, CAD,modeling, and verification groups to ensure the design quality
Drive innovation into the future Memorygeneration with dynamic work environment
Requirements
Deep knowledge and understanding of digitaland analog circuits
Deep knowledge of CMOS device physics andlayout
Experience in large scale mix signal circuitrydesign and verification including logic implementation/verification, timing analysis/optimization
Experience in memory product design andverification (DRAM, SRAM, NAND, NOR..) would be a plus
Excellent problem-solving and analyticalskills
A self-motivated, enthusiastic team player whoenjoys working with others
Good communication skills with the ability toconvey complex technical concepts to other design peers in verbal and writtenform
Knowledge and experience in Finesim and Hspice
Knowledge in verilog verification
Experience with power network analysis
Experience with low power design andverification
Education (One of the following is required)
A Bachelor in Electrical Engineering orrelated discipline plus 10 years of experience.
A Master in Electrical Engineering or relateddiscipline plus 8 years of experience.
MS Degree is preferred.
发表于 2017-3-11 12:25:25 | 显示全部楼层
帮顶~
GMT+8, 2025-9-15 21:17 , Processed in 0.011140 second(s), 3 queries , Gzip On, Redis On.
