楼主: iq24
[原创] 关于二级运放的设计问题
 楼主| 发表于 2017-3-5 11:26:59 | 显示全部楼层
回复 10# AcoAco
兄弟 ,我知道你说的了,我N1 N2确实画错了,谢谢你的提醒!
发表于 2017-3-5 17:17:25 | 显示全部楼层
Reply 1 # iq24
Thank you for correcting.
What is the variation of your op amp's branch bias current? If you change Vdd from 2.6V to 5V, how much is the bias current? You say N7 linearity: if the N7 bias current increases too much, you may need to increase the N7 size (same as the other nch transistor bias). If this does not work than the correct cascade can limit the bias current variation.
 楼主| 发表于 2017-3-5 17:49:48 | 显示全部楼层
有谁还能帮下忙看下吗?谢谢!
 楼主| 发表于 2017-3-6 21:10:41 | 显示全部楼层
哪位大神有相关资料可以参考?
GMT+8, 2025-12-19 15:56 , Processed in 0.012374 second(s), 3 queries , Gzip On, Redis On.
