查看: 7906|回复: 15
[求助] tessent2013 按照问题求教
发表于 2017-3-2 23:40:34 | 显示全部楼层 |阅读模式
将tessent_2013_1_common tessent_2013_1_doc tessent_2013_1_lnx-x86放到同一个路径下,都改为可执行,执行./tessent_2013_1_common
log如下:
Unpacking install file.  Please wait . . .
WARNING: Would install common but the file tessent_2013_1_common was not found.
WARNING: Would install doc but the file tessent_2013_1_doc was not found.
WARNING:  The documentation for DFT tools has been moved and is no longer
available in each platform file.  It must be installed from the separate
file for the 'doc' platform (e.g. dft_2005_5_10_doc.tar).
In order to install documentation for your DFT tools, please return to
where ever you obtained this install file, retrieve the file for 'doc',
and execute it in this directory.
WARNING: Would install lnx-x86 but the file tessent_2013_1_lnx-x86 was not found.
WARNING: Would install sol-sparc but the file tessent_2013_1_sol-sparc was not found.
All requested platforms are currently installed.  Quiting with nothing done.
多谢!!!
发表于 2017-7-28 19:01:42 | 显示全部楼层
1. download  this link -->   http://bbs.eetop.cn/thread-402472-1-1.html
2. uncompress tar file
   tar xvf tessent_2013_1_common.tar
   tar xvf tessent_2013_1_doc.tar
   tar xvf tessent_2013_1_lnx-x86.tar
3.  able to run
   chmod 750 tessent_*
4.  if  Unable to find uudecode!
     google search   " sharutils_xxx.rpm  "
     if ( centos 6 or rhel 6 --- 64bit)
         http://www.filewatcher.com/m/sha ... 4.rpm.191432-0.html
     sudo yum install  sharutils-4.7-6.1.el6.x86_64.rpm
5.  run install
    or
    ./tessent_2013_1_doc
    or
    ./tessent_2013_1_lnx-x86
6. patch
   http://bbs.eetop.cn/thread-470038-1-1.html
      license_gen_可用.zip
发表于 2019-3-26 07:33:01 | 显示全部楼层
感謝幫忙
发表于 2019-3-28 07:36:37 | 显示全部楼层
感謝幫忙
发表于 2019-3-29 13:43:45 | 显示全部楼层
感謝幫忙
发表于 2019-7-15 20:36:24 | 显示全部楼层
感謝幫忙
发表于 2020-12-26 14:26:43 | 显示全部楼层
解决了吗 这个问题我一直没有解决
发表于 2021-5-25 15:11:06 | 显示全部楼层
非常感谢
发表于 2021-6-20 15:24:27 | 显示全部楼层
学习了
发表于 2022-12-7 10:41:05 | 显示全部楼层
在安装tessent_2022_3时遇到同样的问题,提示WARNING: Would install doc but the file tessent_*_doc was not found. 请问有解决吗?
GMT+8, 2025-9-18 05:24 , Processed in 0.019206 second(s), 4 queries , Gzip On, Redis On.
