查看: 9297|回复: 5
[求助] 求大神帮忙,cadence里从cds.log里打不开library是怎么回事啊?
发表于 2017-2-16 18:43:55 | 显示全部楼层 |阅读模式
在cadence终端页面输入某一文件,virtuoso &后cds.log中出现下面一段话:
*WARNING* (icLic-31) virtuoso: Could not export the license service for the session 'virtuoso5535' on host 'bogon'.
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.02s.
*WARNING* The directory: '/home/asiclab/csmc05/opamp' does not exist
but was defined in libFile '/home/asiclab/csmc05/cds.lib' for Lib 'opamp'.
cdsServIpc:  connection timeout (local host)
求大神帮忙,cds.log中打不开labrary了,求各位帮忙,不然毕不了业了
发表于 2017-2-17 08:57:33 | 显示全部楼层
check the library path
 楼主| 发表于 2017-2-17 09:50:59 | 显示全部楼层
回复 2# liuzhihua
您好,我对cadence也不是特别了解,您能具体说一下怎么检查library的路径吗?还有就是,我师弟安装的cadence是年前从我这里拷贝过去的,昨天也发现从终端输入指令后也进不去CDS界面了,请问这是怎么回事啊?求大神帮忙!
发表于 2020-6-10 16:12:57 | 显示全部楼层
想问问楼主怎么搞啊 我也是这样
发表于 2022-8-1 15:36:27 | 显示全部楼层
您好,楼主解决问题了吗?怎么做的呀
发表于 2023-2-28 10:50:28 | 显示全部楼层
把‘cds.lib’里面定义的 'opamp'那个语句删掉呢
GMT+8, 2025-11-14 18:49 , Processed in 0.016586 second(s), 4 queries , Gzip On, Redis On.
