查看: 14912|回复: 15
calibre2016 realtime 提示pcell is not a SKILL super master.
发表于 2017-1-13 21:26:44 | 显示全部楼层 |阅读模式
环境,IC617+calibre2016,OA版本为oa_v22.50.054。
为了开启calibre的realtime功能,已经在bashrc里面添加了如下环境变量
export MGC_CALIBRE_REALTIME_VIRTUOSO_ENABLED=1
export OA_PLUGIN_PATH=$CALIBRE_HOME/shared/pkgs/icv/tools/queryskl
export LD_LIBRARY_PATH=$CALIBRE_HOME/shared/pkgs/icv/tools/calibre_client/lib/64:{LD_LIBRARY_PATH}
有两个问题
1.如果注释掉
virtuoso cds.log里面提示如下warning:
*WARNING* (DB-220706): The Pcell plug-in for super master 'MentorObserverLib/oa_v22_50_001/layout' could not be loaded: Cannot find IPcell 'virtuoso_calibre_client_oa_v22_50_001': Pcell evaluator 'virtuoso_calibre_client_oa_v22_50_001' not found: Shared Library Not Found: Error loading library 'libvirtuoso_calibre_client_oa_v22_50_001.so'. libvirtuoso_calibre_client_oa_v22_50_001.so: cannot open shared object file: No such file or directory...
*WARNING* (DB-220704): The Pcell super master 'MentorObserverLib/oa_v22_50_001/layout' is not a SKILL super master.
                       The usage of non-SKILL Pcells in Virtuoso is not a supported feature.
网上查询获得模糊的信息就是,calibre可以读取OA数据,但是skill pcell不是OA的一部分,所以calibre不能读取,需要用virtuoso将skill pcell stream out 变成GDSII,是这样的原因吗?如果要修复,怎么操作?
2.如果不注释
export LD_LIBRARY_PATH=$CALIBRE_HOME/shared/pkgs/icv/tools/calibre_client/lib/64:${LD_LIBRARY_PATH}
virtuoso 开启一直处于无响应状态,鼠标点击没有任何反映,请问各位这是什么问题?
 楼主| 发表于 2017-1-16 11:32:04 | 显示全部楼层
自己顶一下
发表于 2017-4-2 13:36:05 | 显示全部楼层
楼主你calibre2016哪里下的啊?
发表于 2017-4-3 00:25:17 | 显示全部楼层
同样问题 求教
发表于 2017-8-17 13:14:34 | 显示全部楼层
回复 1# rfham
同样的问题,请问楼主解决了么?
我采用if语句在cshrc中做了判断,但是还是会提示警告感觉是license中缺少相应的feature,我在启动calibre  realtime时无响应。
setenv MGC_CALIBRE_REALTIME_VIRTUOSO_ENABLED 1
setenv OA_PLUGIN_PATH ${CALIBRE_HOME}/shared/pkgs/icv/tools/queryskl
if ($?LD_LIBRARY_PATH) then
  setenv LD_LIBRARY_PATH ${CALIBRE_HOME}/shared/pkgs/icv/tools/calibre_client/lib/64{LD_LIBRARY_PATH}
else
endif
setenv MGC_CALIBRE_REALTIME_VIRTUOSO_SAVE_MESSENGER_CELL 1
出现下面的警告
*WARNING* (DB-220704): The Pcell super master: MentorObserverLib/oa_v22_50_001/layout is not a SKILL super master.
 楼主| 发表于 2017-8-17 15:20:13 | 显示全部楼层
看看这个帖子吧http://bbs.eetop.cn/thread-620762-1-1.html,在19楼
发表于 2017-8-18 10:43:04 | 显示全部楼层
回复 6# rfham
这些我已经改过来。没有用
发表于 2017-12-7 16:24:11 | 显示全部楼层
我也遇到这个问题了
发表于 2018-2-3 13:58:54 | 显示全部楼层
我也遇到这个问题,且realtime 中没有Run DRC on Edit Mode的选项,求解
发表于 2018-5-14 19:07:49 | 显示全部楼层
good material
GMT+8, 2025-12-29 04:09 , Processed in 0.017697 second(s), 3 queries , Gzip On, Redis On.
