查看: 18358|回复: 55
[资料] openpiton 25核开源FPGA代码、ASIC工程、文档
发表于 2017-1-8 14:54:14 | 显示全部楼层 |阅读模式
普林斯顿大学的研究人员在本周举行的Hot Chips研讨会上公布了25核处理器Piton。该芯片是专门为数据中心和程序并行运行设计的,具有强大的可扩展性,可用于构建集成8000多个芯片打造超过20万核心的数据中心系统。该项目获得了美国国家科学基金会和DARPA的资助。目前版本的Piton芯片大小6毫米x6毫米,有超过4.6亿个晶体管,使用IBM的32纳米工艺制造,是至今学术机构开发的最复杂处理器。
OpenPiton®
OpenPiton® is the open source release of the Princeton Piton many-core processor, which has been designed and taped-out in March 2015 in Princeton Parallel Group under supervision of Prof. David Wentzlaff. Some of OpenPiton® features are listed below:
OpenSPARC T1 Cores (SPARC V9)
Written in Verilog HDL
Scalable up to 1/2 Billion Cores
Large Test Suite (>8000 tests)
Single Tile FPGA (Xilinx ML605) Prototype
Princeton Piton Processor, is a many-core designed by Prof. Wentzlaff's research group in March, 2015. It is taped-out in IBM 32nm SOI process. Some of Piton's features are listed below:
25 modified OpenSPARC T1 cores
Directory-based shared memory
3 On-chip networks
Multi-chip shared memory support
1 GHz clock frequency
IBM 32nm SOI process (6mm*6mm)
460 million transistors
openpiton-src-16-04-03-r3.part1.rar (15 MB , 下载次数: 304 )
openpiton-src-16-04-03-r3.part2.rar (15 MB , 下载次数: 339 )
openpiton-src-16-04-03-r3.part3.rar (15 MB , 下载次数: 321 )
openpiton-src-16-04-03-r3.part4.rar (15 MB , 下载次数: 302 )
openpiton-src-16-04-03-r3.part5.rar (15 MB , 下载次数: 285 )
openpiton-src-16-04-03-r3.part6.rar (15 MB , 下载次数: 310 )
openpiton-src-16-04-03-r3.part7.rar (8.79 MB , 下载次数: 124 )
openpiton-src-16-10-26-r4.part7.rar (8.95 MB , 下载次数: 129 )
openpiton-src-16-10-26-r4.part1.rar (15 MB , 下载次数: 249 )
openpiton-src-16-10-26-r4.part2.rar (15 MB , 下载次数: 256 )
openpiton-src-16-10-26-r4.part3.rar (15 MB , 下载次数: 232 )
openpiton-src-16-10-26-r4.part4.rar (15 MB , 下载次数: 234 )
openpiton-src-16-10-26-r4.part5.rar (15 MB , 下载次数: 241 )
openpiton-src-16-10-26-r4.part6.rar (15 MB , 下载次数: 289 )
发表于 2017-1-9 15:33:02 | 显示全部楼层
学习学习!哈哈哈
发表于 2017-1-9 17:56:24 | 显示全部楼层
thanks
发表于 2017-1-10 11:03:16 | 显示全部楼层
多谢分享,下下来看看。  这个跟riscv比咋样?
 楼主| 发表于 2017-1-11 13:11:07 | 显示全部楼层
回复 4# y23angchen
    当然比riscV要强得多!
发表于 2017-1-12 23:01:33 | 显示全部楼层
回复 1# 固执的寻觅
   thanks for sharing
发表于 2017-1-13 12:20:50 | 显示全部楼层
Thanks for sharing.
发表于 2017-1-13 17:56:17 | 显示全部楼层
发表于 2017-1-13 22:38:58 | 显示全部楼层
牛逼,不过不懂
发表于 2017-1-15 20:05:41 | 显示全部楼层
太复杂了,有人能简单介绍下怎么玩risc-v吗?
GMT+8, 2025-12-13 13:32 , Processed in 0.020908 second(s), 4 queries , Gzip On, Redis On.
