查看: 10196|回复: 32
esd_circuit_simluation
发表于 2007-6-12 12:34:44 | 显示全部楼层 |阅读模式
ESD 仿真的文档
esd_circuit_simluation.pdf
282.35 KB, 下载次数: 201 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-6-18 00:54:44 | 显示全部楼层
一个字,值。谢谢楼主
发表于 2007-6-18 10:01:12 | 显示全部楼层
kankan!
发表于 2007-6-18 10:11:45 | 显示全部楼层
abstract:
This work presents cirsuit-level simulation and layout optimization techniques for a multifinger NMOS device. By considering the full thermal-coupling of heat sources at each drain finger,simulation reflect the device layout depent behaviour in silicon under EOS/ESD, simulation reveals that each NMOS finger many carry a different stress current due to the total NMOS width will be reduced. simulation results agree well with measured data. we also proposed s design and layout optomization methodology which is illustrated with a design example.
发表于 2008-11-9 13:49:14 | 显示全部楼层
dasdasdsad
发表于 2008-11-9 18:26:54 | 显示全部楼层
3q3q3q3q3q
发表于 2008-11-20 14:03:07 | 显示全部楼层
thank you very much.
发表于 2008-11-20 14:20:56 | 显示全部楼层
扫描的版本
发表于 2008-11-22 16:50:08 | 显示全部楼层
thank you!!!
发表于 2009-3-14 01:09:22 | 显示全部楼层
3Q~~
GMT+8, 2025-12-10 07:30 , Processed in 0.026746 second(s), 8 queries , Gzip On, Redis On.
