查看: 2524|回复: 3
[招聘] [上海浦东] 美光(Micron)招聘验证工程师
发表于 2016-12-16 13:52:13 | 显示全部楼层 |阅读模式
美光浦东外高桥site招聘验证工程师,有意向请联系ysheng@micron.com
JD如下:
IC Design ValidationEngineer
Description
As a ValidationDesigner at Micron's NAND design team, you will work in a highly innovative andmotivated design team using state of the art memory technologies to developFlash product.
You willparticipate in VLSI circuit design and verification in the circuit areas. Aspart of a multi-disciplinary team, you will participate in developingdigital/analog mix-signal verification methodology for Flash products anddesign and implementation of mix-signal design verification environment aswell. As an important part of responsibility, you will develop and maintaintest benches and test vectors using digital and analog simulation tools.
Requirements
-Must possessgood communication skills and ability to work well in a team
-Familiar with SystemVerilog ,Verilog or VHDL
-Basicunderstanding of CMOS circuit design
-Familiar withanalog/digital or mix-signal simulator, ie. modelsim, XA etc
-Experience inSV and SVA coding preferred
-Experience incomplex IC verification and/or IC design preferred
-Familiar withUnix platform, perl and tcl programming skill is a plus
-Previous workexperience in Flash memory related fields is a plus
-Englishlanguage skill in writing and speaking is a plus
Education
BS or MS inElectrical Engineering is required
发表于 2016-12-16 22:21:40 | 显示全部楼层
求教,美光在外高桥和漕河泾有什么差别?
 楼主| 发表于 2016-12-19 08:21:36 | 显示全部楼层
回复 2# 小北街七号
   美光漕河泾主要做DRAM design,美光外高桥主要做NAND Flash Design
 楼主| 发表于 2016-12-21 12:37:26 | 显示全部楼层
回复 1# bill_syue
   自己顶
GMT+8, 2025-12-25 10:50 , Processed in 0.013446 second(s), 3 queries , Gzip On, Redis On.
