我用的FPGA型号是XC6VLX240T,我想把外界输入的时钟Rx_clk_i(125MHz),延时2ns左右,再给到内部逻辑,下面是IODELAYE1的例化
IODELAYE1 #(
.CINVCTRL_SEL("FALSE"), // Enable dynamic clock inversion ("TRUE"/"FALSE")
.DELAY_SRC("CLKIN"), // Delay input ("I", "CLKIN", "DATAIN", "IO", "O")
.HIGH_PERFORMANCE_MODE("TRUE"), // Reduced jitter ("TRUE"), Reduced power ("FALSE")
.IDELAY_TYPE("FIXED"), // "DEFAULT", "FIXED", "VARIABLE", or "VAR_LOADABLE"
.IDELAY_VALUE(20), // Input delay tap setting (0-32)
.ODELAY_TYPE("FIXED"), // "FIXED", "VARIABLE", or "VAR_LOADABLE"
.ODELAY_VALUE(0), // Output delay tap setting (0-32)
.REFCLK_FREQUENCY(200.0), // IDELAYCTRL clock input frequency in MHz
.SIGNAL_PATTERN("CLOCK") // "DATA" or "CLOCK" input signal
IODELAYE1_Rx_clk (
.CNTVALUEOUT(), // 5-bit output - Counter value for monitoring purpose
.DATAOUT(Rx_clk_delay), // 1-bit output - Delayed data output
.C(0), // 1-bit input - Clock input
.CE(0), // 1-bit input - Active high enable increment/decrement function
.CINVCTRL(0), // 1-bit input - Dynamically inverts the Clock (C) polarity
.CLKIN(Rx_clk_i), // 1-bit input - Clock Access into the IODELAY
.CNTVALUEIN(0), // 5-bit input - Counter value for loadable counter application
.DATAIN(0), // 1-bit input - Internal delay data
.IDATAIN(0), // 1-bit input - Delay data input
.INC(0), // 1-bit input - Increment / Decrement tap delay
.ODATAIN(0), // 1-bit input - Data input for the output datapath from the device
.RST(IODELAYE1_reset_w), // 1-bit input - Active high, synchronous reset, resets delay chain to IDELAY_VALUE/
// ODELAY_VALUE tap. If no value is specified, the default is 0.
.T(0) // 1-bit input - 3-state input control. Tie high for input-only or internal delay or
// tie low for output only.
我不知道上面例化填写的端口对不对,想请问,输入时钟Rx_clk_i是接在CLKIN端口呢,还是接在IDATAIN端口呢,或者别的接口,Input delay tap setting如何计算设置呢,另外还需要例化一个IDELAYCTRL,
IDELAYCTRL IDELAYCTRL_Rx_clk (
.RDY(), // 1-bit Ready output
.REFCLK(Clk_125M), // 1-bit Reference clock input
.RST(Clk_125M_rst) // 1-bit Reset input
请问这个IDELAYCTRL 的REFCLK用哪个时钟呢,有什么影响吗?它的复位RST是否需要单独处理呢,我在UCF文件中对IDELAYCTRL的位置进行约束,如下,
INST "IDELAYCTRL_Rx_clk" LOC=IDELAYCTRL_X2Y1;但是综合时提示INST "IDELAYCTRL_Rx_clk" not
found. 请问这是为什么呢,另外这个IDELAYCTRL的具体位置根据什么找呢, |
