查看: 8127|回复: 29
[原创] UIUC并行计算、异构加速设计研究报告
发表于 2016-12-2 21:44:32 | 显示全部楼层 |阅读模式
UPCRC_Whitepaper.pdf (1.73 MB , 下载次数: 111 )
For many decades, Moore’s law has bestowed a wealth of transistors that hardware designers and compiler
writers have converted to usable performance, without changing the sequential programming interface. The
main techniques for these performance benefits—increased clock frequency and smarter but increasingly
complex architectures—are now hitting the so-called power wall. The computer industry has accepted that
future performance increases must largely come from increasing the number of processors (or cores) on a die,
rather than making a single core go faster. This historic shift to multicore processors changes the programming
interface by exposing parallelism to the programmer, after decades of sequential computing.
Parallelism has been successfully used in many domains such as high performance computing (HPC), servers,
graphics accelerators, and many embedded systems. The multicore inflection point, however, affects the entire
market, particularly the client space, where parallelism has not been previously widespread. Programs with
millions of lines of code must be converted or rewritten to take advantage of parallelism; yet, as practiced
today, parallel programming for the client is a difficult task performed by few programmers. Commonly used
programming models are prone to subtle, hard to reproduce bugs, and parallel programs are notoriously hard
to test due to data races, non-deterministic interleavings, and complex memory models. Mapping a parallel
application to parallel hardware is also difficult given the large number of degrees of freedom (how many
cores to use, whether to use special instructions or accelerators, etc.), and traditional parallel environments
have done a poor job virtualizing the hardware for the programmer. As a result, only the highest performance
seeking and skilled programmers have been exposed to parallel computing, resulting in little investment in
development environments and a lack of trained manpower. There is a risk that while hardware races ahead
to ever-larger numbers of cores, software will lag behind and few applications will leverage the potential
hardware performance.
Moving forward, if every computer will be a parallel computer, most programs must execute in parallel and
most programming teams must be able to develop parallel programs, a daunting goal given the above problems.
Illinois has a rich history in parallel computing starting from the genesis of the field and continues a broad
research program in parallel computing today [1]. This program includes the Universal Parallel Computing
Research Center (UPCRC), established at Illinois by Intel and Microsoft, together with a sibling center
established at Berkeley. These two centers are focused on the problems of multicore computing, especially
in the client and mobile domains.
This paper describes the research vision and agenda for client and mobile computing research at Illinois,
focusing on the activities at UPCRC (some of which preceded UPCRC).
Given the long history of parallel computing, it is natural to ask whether the challenges we face today differ
from those of the past. Compared to the HPC and server markets, the traditional focus of parallel computing
research, the client market brings new difficulties, but it also brings opportunities. Table 1 summarizes
some of the key differences.
发表于 2016-12-3 14:58:23 | 显示全部楼层
thanks.down
发表于 2016-12-3 15:37:11 | 显示全部楼层
谢谢分享!!
发表于 2016-12-3 19:51:51 | 显示全部楼层
kankan
发表于 2016-12-5 18:44:23 | 显示全部楼层
很好!
 楼主| 发表于 2016-12-14 16:46:56 | 显示全部楼层
回复 5# shanganp
   zan
发表于 2017-1-16 10:52:19 | 显示全部楼层
谢谢分享,赞一个
发表于 2017-2-16 13:20:15 | 显示全部楼层
谢谢分享!
发表于 2017-2-25 10:49:46 | 显示全部楼层
感谢分享~
发表于 2017-3-4 19:51:57 | 显示全部楼层
thnx!
GMT+8, 2025-9-21 04:29 , Processed in 0.017965 second(s), 4 queries , Gzip On, Redis On.
