查看: 3728|回复: 6
[原创] 跨阻放大器TIA
发表于 2016-11-28 19:43:41 | 显示全部楼层 |阅读模式
眼图
眼图
为啥眼图的上下沿不对称呢~~~反而看起来有点像旋转了180度~~~
 楼主| 发表于 2016-11-28 19:44:58 | 显示全部楼层
不对不对,,,是关于中心线对称
发表于 2016-11-28 20:44:27 | 显示全部楼层
This output should be single-end signal, rising time!=falling time.
BTW differential signal can solve the above problem
 楼主| 发表于 2016-11-29 20:53:21 | 显示全部楼层
回复 3# zaimang101
   这不应该是跟我设置的伪随机序列的trise和tfall有关吗?为什么单端信号上升沿和下降沿的走势不同呢??
发表于 2016-11-29 21:18:32 | 显示全部楼层
回复 1# christine~
    dsafsdafsd
发表于 2016-11-29 21:57:04 | 显示全部楼层
回复 4# christine~
Yes, the rising time/ falling time of input PRBS does matter. But the equations of charge/discharge of load cap through resistor to supply/gnd are different{ Vdd*(1-exp(-t/tau1)) @charging, vdd*exp(-t/tau2)@discharging} , generally speaking tau1 != tau2.I don't seize what you want to say. what do you mean by "走势"?
 楼主| 发表于 2016-12-7 19:30:19 | 显示全部楼层
回复 6# zaimang101
   THX,原谅我这个新手的不专业词语,,,“走势”就是说曲线的变化趋势
GMT+8, 2025-12-23 00:26 , Processed in 0.018059 second(s), 4 queries , Gzip On, Redis On.
