查看: 1302|回复: 0
[招聘] NO.59-Physical Design Engineering Lead(Shanghai)
发表于 2016-11-18 11:18:36 | 显示全部楼层 |阅读模式
Responsibilities include:
    Audit customer design for PnR processing
    Perform physical design flow from Netlist to GDSII with timing closure, DRC clean: Audit Netist/ timing constraints; Clock tree synthesis and Hold fixing; Routing and post routing optimization
    Timing sign-off: Timing clean database with timing signoff tools
    Synthesis & Floor planning, Power structure designing
    work on complex block place & route and/or top level place and route (P&R) for advanced nodes (40nm and below)
    interface with Front End, DFT team, Physical Verification team
    assist in interfacing with IP vendors and EDA vendor
    analyze and propose solution to meet timing closure and schedule
    assist in communicating with customer and manage expectations
    Lead and coordinate WW design teams to ensure on time delivery of design results.  (design lead role only)
Background and Experience Requirements:
To be qualified for this position candidates must possess:
    7+ years as a ASIC P&R engineer
    experience as project lead, deisgn lead is a plus
    experience with Atoptech, Synopsys and Cadence: P&R, PT STA, Formal verification
    experience with SDC constraints debug
    complex high speed interfaces (serdes, DDR3, MIPI)
    experience with IP integration
    TCL and scripting
    experience with advanced nodes (40nm and below)
    BS of Electrical Engineering or similar. MSEE a plus.
    Outstanding communications skills (including English) and team player
    Eligible to work in country of hire (China) without restriction.
Only those candidates who meet the requirements listed herein will be given consideration.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“凯轶—KT咨询”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“凯轶—KT咨询”即可添加,欢迎大家关注!
或者直接扫我哦!
GMT+8, 2025-12-30 13:03 , Processed in 0.017013 second(s), 5 queries , Gzip On, Redis On.
