查看: 3530|回复: 0
[求助] 衬底漏电流对电路的影响
发表于 2016-11-4 16:46:46 | 显示全部楼层 |阅读模式
1.一个电流比较器电路中,NMOS衬底接高电位,源衬二极管正偏,衬底瞬态最大漏电流是750nA, 稳态漏电流是8nA,漏源电流是2uA, 但是仿真结果仍然正确,那这个电路能用吗?
2.电路中衬底漏电一般是多大可以容忍?
《A Body-Bias based Current Sense Amplifier for High-Speed Low-Power Embedded SRAMs》文中就采用了The low voltage level at the M3
substrate (Vdd-ΔVBitline) and the high voltage at the source(Vdd) make this transistor forward-body biased FBB, with source-body voltage difference VSB=ΔVBitline. 这个不是也有衬底漏电吗?
GMT+8, 2025-11-17 01:35 , Processed in 0.014980 second(s), 4 queries , Gzip On, Redis On.
