发表于 2007-6-18 12:38:46
显示全部楼层
原帖由 cisse 于 2007-6-18 09:33 发表
you say the input impedance is 2/Gm.I think when the Rdsmc2=R(the impedance looking into the source of the MC4),it's OK?Am I right?
And the sentance:the output capactiance is increased,the domin ...
I do not understand the first question. "2/Gm" is a general result for cascode structure. It is derived from Kirchoff law. However, if you try to derive it from the point view of physics, you will find it is "1/Gm". The difference is small but very critical since no similiar case exsits in other circuits.
As for the 2nd question, the output impedence is pretty larger than any other nodes. Thus, dominant pole is at the ouput while the other poles are high frequency. |
