查看: 2851|回复: 5
[求助] Power Supply Design
发表于 2016-10-30 12:01:30 | 显示全部楼层 |阅读模式
求《Power Supply Design》一书,by Dr.Ridleyhttp://www.ridleyengineering.com/books.html
file:///C:\Users\Administrator\AppData\Roaming\Tencent\Users\1064956213\QQ\WinTemp\RichOle\WH9}LWZJYB58HG_3X6CR41Z.png
This is a book about control of PWM converters. It is intended to guide the reader through the confusing array of choices available in designing a
modern switching power supply. This book highlights the main control
issues encountered in dc-dc converters.
Use this book in conjunction with our free Control Analysis Software that can be
downloaded from our website. The software contains all the equations for the three major families of converters, operating with both CCM and DCM, using
either voltage-mode or current-mode control.
The harsh reality of power supply development is that they rarely behave in an expected manner, or in the manner that simulators dictate. Therefore,
you must build hardware, then test and measure as quickly as possible to
uncover problems. This book is intended to help you get there faster by
providing key information, and showing where the issues lie."
This 170-page hardcover book is in full color, for maximum clarity. Nine chapters of design ideas and explanations include the following:
  • Nine Topologies
  • Modeling Power Topologies
  • Voltage-Mode Compensation
  • Current-Mode Control Modeling
  • Current-Mode Compensation
  • Frequency Response Measurements
  • System Issues
  • Input Filter Interactions
  • Noise Issues
发表于 2018-7-9 09:03:35 | 显示全部楼层
thank you very much
发表于 2018-3-26 22:20:58 | 显示全部楼层
我刚才同事桌子上 偷了一本
发表于 2016-12-12 12:33:09 | 显示全部楼层
anybody could provide the eBook
发表于 2016-11-2 13:41:36 | 显示全部楼层
同求
发表于 2016-11-2 09:45:50 | 显示全部楼层
同求!!
GMT+8, 2025-12-25 10:28 , Processed in 0.017820 second(s), 5 queries , Gzip On, Redis On.
