查看: 1954|回复: 4
[原创] dOES ANY ONE FELT SAME ISSUE? hELP
发表于 2016-7-28 05:31:06 | 显示全部楼层 |阅读模式
i am getting following error
error
error
how to solve the issue happened while invoking Transient analysis with hspice. on forum some said its license issue. if it so, please root me to find the correct license generation with synopsys cdesigner enabled feature license.
any help
发表于 2016-7-28 09:36:42 | 显示全部楼层
you can try to simulate a simple circuit, such as a resistor divider without any process library, if the simulation can finish correctly, then the license may be ok.
it seems the "icui18n" lib is not correct, is this a process model lib?
 楼主| 发表于 2016-7-28 19:09:47 | 显示全部楼层
回复 2# david_reg
same happen for resistive divider
    same error happened again for any kinda circuits schematics. It may be some other libpackage issue.
Any solution?
发表于 2016-7-29 09:36:20 | 显示全部楼层
here is url for a similar problem and there is a solution, hope it is help for you.
http://bbs.csdn.net/topics/390207762
 楼主| 发表于 2016-7-30 08:10:08 | 显示全部楼层
回复 4# david_reg
   Thnx the concern. Let me try, it might be work to me so.
GMT+8, 2025-12-25 18:38 , Processed in 0.021776 second(s), 6 queries , Gzip On, Redis On.
