查看: 2794|回复: 2
[求助] 求救:calibre在ubuntu下安装后启动报错!
发表于 2016-5-10 23:29:15 | 显示全部楼层 |阅读模式
系统为ubuntu10.04,calibre从2009、2010、2011,已经试过好几个版本,报错基本都是“Can't find a usable tk.tcl in the following directories”
报错如下所示
WARNING: Could not find /etc/redhat-release or /etc/SuSE-release
WARNING: Calibre is not supported on with this Linux version
Application initialization failed: Can't find a usable tk.tcl in the following directories:
    /EDA/Mentor/Calibre_2011/x86_cal_2011.2_34.26/pkgs/icv_comp/8.4/lib/tk8.4 /EDA/Mentor/Calibre_2011/x86_cal_2011.2_34.26/pkgs/icv_comp/8.4/lib/tcl8.4/tk8.4 /EDA/Mentor/Calibre_2011/x86_cal_2011.2_34.26/pkgs/icv/lib/tk8.4 /EDA/Mentor/Calibre_2011/x86_cal_2011.2_34.26/pkgs/lib/tk8.4 /EDA/Mentor/Calibre_2011/x86_cal_2011.2_34.26/pkgs/icv/library /EDA/Mentor/Calibre_2011/x86_cal_2011.2_34.26/pkgs/library /EDA/Mentor/Calibre_2011/x86_cal_2011.2_34.26/pkgs/tk8.4.9/library /EDA/Mentor/Calibre_2011/x86_cal_2011.2_34.26/tk8.4.9/library
/EDA/Mentor/Calibre_2011/x86_cal_2011.2_34.26/pkgs/icv_comp/8.4/lib/tk8.4/tk.tcl: can't access "::tk:riv.::ffff:192.168.0.104:0": parent namespace doesn't exist
    while executing
"upvar #0 ::tk:riv.::ffff:192.168.0.104:0 ::tk::Priv"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 upvar #0 ::tk::Priv.$disp ::tk::Priv"
    (procedure "tk::ScreenChanged" line 9)
    invoked from within
"tk::ScreenChanged [winfo screen .]"
    (file "/EDA/Mentor/Calibre_2011/x86_cal_2011.2_34.26/pkgs/icv_comp/8.4/lib/tk8.4/tk.tcl" line 281)
    invoked from within
"source /EDA/Mentor/Calibre_2011/x86_cal_2011.2_34.26/pkgs/icv_comp/8.4/lib/tk8.4/tk.tcl"
    invoked from within
"uplevel #0 [list source $file]"
This probably means that tk wasn't installed properly.
tk需要怎么怎么安装?紧急求救
 楼主| 发表于 2016-5-10 23:37:42 | 显示全部楼层
500 信元紧急求助!
 楼主| 发表于 2016-5-11 09:16:17 | 显示全部楼层
希望路过的朋友进来帮忙看看,Can't find a usable tk.tcl in the following directories
GMT+8, 2025-12-30 08:05 , Processed in 0.019671 second(s), 5 queries , Gzip On, Redis On.
