楼主: ald_syn_cad
Mentor acquired calypto- Please share catapult
发表于 2016-5-16 08:48:41 | 显示全部楼层
回复 28# ald_syn_cad
Gantt and schematic button are gray, not able to analysis. warning in the log# Warning: Could not read Encrypted Liberty technology library file 'sample_065nm.clib' specified in a catapult library, in the paths specified () (LIB-147)
# Warning: Downstream flows that depend on a Encrypted Liberty file(s) will not be able to run. Please check option ComponentLibs/TechLibSearchPath. (LIB-191)
# Warning: Could not read Liberty technology library file 'sample_065nm.lib' specified in a catapult library, in the paths specified () (LIB-147)
# Warning: Downstream flows that depend on a Liberty file(s) will not be able to run. Please check option ComponentLibs/TechLibSearchPath. (LIB-191)
# Warning: Could not read Synopsys DB technology library file 'sample_065nm.db' specified in a catapult library, in the paths specified () (LIB-147)
# Warning: Downstream flows that depend on a Synopsys DB file(s) will not be able to run. Please check option ComponentLibs/TechLibSearchPath. (LIB-191)
license not complete?
发表于 2016-5-16 11:13:41 | 显示全部楼层
太谢谢啦,成功安装
 楼主| 发表于 2016-5-16 16:49:42 | 显示全部楼层
Yes, I have the same problem.
Really don't have any idea about it. I created it according to the previously mentioned method.
Maybe the bug is with the tool itself.
How about testing the previous versions of catapult8 with this license.
发表于 2016-5-17 10:34:00 | 显示全部楼层
哪位大牛出手?
发表于 2016-5-17 18:36:46 | 显示全部楼层
upppp
发表于 2016-5-17 21:07:02 | 显示全部楼层
   应该是license的问题,而不是破解的问题。
 楼主| 发表于 2016-5-19 03:36:06 | 显示全部楼层
Did someone find any solution?
I tested all of the possible ways I knew but not solved.
发表于 2016-5-24 15:33:31 | 显示全部楼层
great post
发表于 2016-5-26 11:33:55 | 显示全部楼层
Well  i also have no Gantt button .has the tool changed or some type of bug .I don't  think is
license related
 楼主| 发表于 2016-5-27 00:43:24 | 显示全部楼层
I think the bug with the tool itself. Maybe needed to upload the previous version.
GMT+8, 2025-12-29 12:57 , Processed in 0.018355 second(s), 3 queries , Gzip On, Redis On.
