楼主: ald_syn_cad
Mentor acquired calypto- Please share catapult
 楼主| 发表于 2016-5-10 03:28:53 | 显示全部楼层
No problem.
If is it possible for you, please upload the Linux version of  "CatapultC", "PowerPro", and "SLEC" (32 bit).
These 3 tools are the best tool in the EDA market, I think.
Their integration satisfies all of the needs of any IP creator.
Thanks!
And for the CatapultC users looking for a good C++ compiler (current version of CatapultC is based on ver 4.9.2):
http://www.equation.com/servlet/equation.cmd?fa=fortran
This one is the best one you can find. You can try other versions too.
I have tested the builds from MinGW, WOW64 and CYGWIN. Unfortunately CatapultC has problem with them.
 楼主| 发表于 2016-5-10 03:29:28 | 显示全部楼层
No problem.
Thanks!
发表于 2016-5-10 04:07:08 | 显示全部楼层
xie xie
发表于 2016-5-11 16:32:06 | 显示全部楼层
xiexiele
is there any crack method?
发表于 2016-5-12 20:32:55 | 显示全部楼层
   When used for Xilinx FPGA,  is CatapultC better than vivado HLS of Xilinx itself ?
发表于 2016-5-14 09:28:19 | 显示全部楼层
is there linux version?
发表于 2016-5-15 09:43:09 | 显示全部楼层
回复 5# adialbu
我用cataput 2011a的license为何提示如下错误?
Licensing Messages:
Error: License verification failed, pid = CatapultUltra, (feature unavailable)
Error: License request for CatPrime2Ultra feature failed
Error: License verification failed, pid = CatapultPrime, (feature unavailable)
Error: License request for CatHLS2Prime feature failed
Error: License verification failed, pid = CatapultHLS, (feature unavailable)
Error: License request for CatapultHLS feature failed
Error: License verification failed, pid = CatapultSL, (feature unavailable)
Error: License request for CatapultSL feature failed
Error: License verification failed, pid = CatapultLP, (feature unavailable)
Error: License request for catapultcoresl feature failed
Error: License verification failed, pid = catapultcorebl, (feature unavailable)
Error: License request for catapultcorebl feature failed
Error: License verification failed, pid = catapultcoreuv, (feature unavailable)
Error: License request for catapultcoreuv feature failed
Error: License verification failed, pid = catapultlbcore, (feature unavailable)
Error: License request for catapultlbcore feature failed
 楼主| 发表于 2016-5-15 16:01:55 | 显示全部楼层
1- First extract install_win.exe to somewhere and then close it.
2- Copy and replace MGLS.DLL in the archive to bin folder. Copy LICENSE.TXT to a location.
3- Inside LICENSE.TXT, change Your_Pc and also xxxxxxxxxxxx in the whole file according to your ones.
4- Create an environment variable with the variable name: LM_LICENSE_FILE and in the variable value, point to the license file's location.
5- Run catapult.exe in bin folder again and follow the installation process.
Try before buy. Please use this tool just as educational purposes. Commercial use is strongly prohibited.
For using this tool, you need my previously mentioned C++ compiler.
Please upload PowerPro and SLEC.
Thanks!
Patch&Lic.rar
953.43 KB, 下载次数: 186 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2016-5-16 00:43:50 | 显示全部楼层
Who can upload, if it possible vista architect?
And white paper from mentor "Modeling and Synthesizing Large Ratio Rate Adapters"
Thanks!
发表于 2016-5-16 00:46:57 | 显示全部楼层
Many thanks!
GMT+8, 2025-12-30 19:52 , Processed in 0.019592 second(s), 4 queries , Gzip On, Redis On.
