查看: 5728|回复: 11
[求助] 各位前辈来指点下ADC咋入门
发表于 2016-4-22 17:52:43 | 显示全部楼层 |阅读模式
如题,目前研一虽然是通信专业,不过老师是微电子方向的,目前和老师说想做ADC方向,由于不是微电子,课程得自己下课看,目前知道ADC有SAR、PIpeline。。。是不是应该选某一个作为方向,然后研究,各位有经验的前辈来指点下
发表于 2016-4-25 16:50:42 | 显示全部楼层
For Reference :
SAR : good: Most popular in industry now.
         good: find a job for future is easy because you has SAR ADC circuit design experience
          bad : can only learn fast comparator circuit skills and capacitor mismatch calculation
                   does not has high performance Amplifier circuit experience
Pipelined : good : can learn much more circuit skills include:
                          common mode feedback , high perofmrance differential amplifier,charge
                          injection skills. Once you has designed a pipelined ADC done. you will find
                          other circuit is more easy than to design a pipelined ADC.
            bad: industry does not use pipelined ADC recently.
发表于 2016-4-26 11:06:44 | 显示全部楼层
个人感觉看老师想把ADC用在什么上了吧。比如速度不同、精度不同,ADC的种类也不同咯
发表于 2016-4-26 11:22:33 | 显示全部楼层
补充一个:
sigma delta ADC
Good: most popular for high resolution requirement application.
Good: if you have done a good sigma delta ADC, you will get a good understanding about the signal/noise/sampling/frequency domain and time domain transfer. Easy to get a job.
Bad: for high sampling rate, it is not easy to implement.  The power is not low enough for some low power application.
发表于 2016-4-26 16:49:48 | 显示全部楼层
先看系统架构,再学运放
发表于 2016-4-26 20:33:10 | 显示全部楼层
欢迎楼主来实习。
诚聘模拟IC设计实习工程师 地点:上海、嘉兴
职位一:ADC方向,要求有ADC理论;职责:ADC等模拟电路设计、维护、改进、测试等。
职位二:电源管理方向,要求有ACDC或DCDC理论背景;职责:电路设计、维护、改进、测试等。
联系:sv@sovan.com.cn
 楼主| 发表于 2016-9-3 14:31:48 | 显示全部楼层
回复 3# sam12321mas
   现在实验室分低功耗和高性能这两个方向,估计就在SAR.SIGMA DELTA,PIPELINE这三者选择
 楼主| 发表于 2016-9-3 14:36:19 | 显示全部楼层
回复 6# leehying
   实习估计得明年了
 楼主| 发表于 2016-9-3 14:48:31 | 显示全部楼层
回复 4# bright_pan
还以为和上面那位用英文回答的是同一人呢,目前感觉老师不想让我和师兄做同样的sigma delta,估计就在pipeline和sar之间,不过感觉可能更想让我做pipeline,自己怕时间不够,听说pipeline比sar和sigma delta开发时间更长,不知道一年时间行不行。。。。。。
 楼主| 发表于 2016-9-3 14:50:53 | 显示全部楼层
回复 5# mikeppq
   是,我也是这么想的,前辈能说下,这三种架构耗时大概多久吗,我目前研二,刚开学,PIPELINE,sar,sigma delta
GMT+8, 2025-12-25 04:53 , Processed in 0.027074 second(s), 5 queries , Gzip On, Redis On.
