查看: 6663|回复: 24
[招聘] 【synopsys武汉】急招 数字验证工程师
发表于 2016-4-7 17:53:39 | 显示全部楼层 |阅读模式
Hi All,
这边是Synopsys HR, Aria, 我们在武汉的研发中心招聘验证工程师, 有意向的朋友,欢迎发送简历到
qyzhong@synopsys.com,另有各类模拟、数字职位,欢迎有意向的朋友发送简历
收到简历后,我们会尽快与你联系,谢谢!
Job Title:   数字IP前端验证工程师
Email: qyzhong@synopsys.com
Must have relevant experience in the following areas:
-Verification of IP Cores or SoC Designs for Set Top Boxes, Mobile handsets, Smart Devices, etc.
-Knowledge of one or more of interface IP protocols is pluse.
-Hands on experience with creating detailed design of certain simple components of Test Environment from Functional Specifications/ Test Environment Specifications. The TE must have used methodologies such as UVM/ VMM.
-Hands on experience with System Verilog/ VERA coding and Simulation tools; Knowledge of C++/ OOPs Concepts
-Experience with Perforce or similar revision control environment
-Knowledge of Perl/Shell scripts.
The candidate will be part of the Solutions Group at our new Design Center at Wuhan, China. This is a Technical Individual Contributor role and offers challenges to work in a multi-site environment on technically challenging IP Cores in the Verification domain. The position offers learning and growth opportunities in Synopsys’ new Design Center at Wuhan.
Job Responsibilities
-Be an individual contributor in the Verification Tasks – coding of TE, debug, verification coverage improvement, etc.
-May need to understand Standard Specifications/ the functional specifications/ feature enhancements for the product and create micro-architecture and detailed design documents for some of the components of small complexity modules in the Test Environment for the DesignWare family of synthesizable cores in protocol areas such some interface IP.
-Creates deliverables which do not require close review or supervision by a Senior Technical Lead.
-May learn to do technical review of TE Code of small complexity.
-The candidate should be able to analyze the coverage metrics and improve them with definition of additional test cases in CRV environment, at least for small/ medium complexity features of the protocol/ product specs.
-The candidate will work in a project and team oriented environment with teams spread across multiple sites, worldwide.
发表于 2016-4-10 20:32:09 | 显示全部楼层
不错的机会,顶一下
 楼主| 发表于 2016-4-11 17:07:03 | 显示全部楼层
update,欢迎有兴趣的朋友投递简历
 楼主| 发表于 2016-4-14 14:08:16 | 显示全部楼层
update
 楼主| 发表于 2016-4-15 13:13:45 | 显示全部楼层
update
发表于 2016-4-17 21:04:08 | 显示全部楼层
人在武汉,简历已发,求给个面试机会
 楼主| 发表于 2016-4-19 15:27:08 | 显示全部楼层
update
 楼主| 发表于 2016-4-20 15:19:07 | 显示全部楼层
update
发表于 2016-4-20 20:05:04 | 显示全部楼层
人在成都,想回武汉,有机会面试么?
 楼主| 发表于 2016-4-21 09:14:42 | 显示全部楼层
回复 9# 不回忆君
   请将您的联系方式发给我,or将您的个人简历发送至我的邮箱qyzhong@synopsys.com, 我们的面试形式很灵活,异地可以采用电话或者Skype面试。感谢您对synopsys武汉职位的关注,欢迎投递简历
GMT+8, 2025-9-15 09:26 , Processed in 0.017063 second(s), 4 queries , Gzip On, Redis On.
