查看: 6174|回复: 4
小白求助 为什么写完脚本 要运行sde时总不行 每次都出现下面代码
发表于 2016-3-29 20:14:30 | 显示全部楼层 |阅读模式
gsub is running on host 'localhost' by user 'pvlab'
Binary 'gsub'
Command line options '-verbose -swb_pid 3061 -q local:default -e remaining /home/pvlab/synopsys/STDB/tmp1.pro'
Current directory '/home/pvlab/Desktop'
Some relevant environment variables:
STROOT=/home/pvlab/synopsys/sentaurus/bin/..
STRELEASE=current
STROOT_LIB=/home/pvlab/synopsys/sentaurus/bin/../tcad/current/lib
STDB=/home/pvlab/synopsys/STDB
DATEX=/home/pvlab/synopsys/sentaurus/bin/../tcad/current/lib/datexcodes.txt
DISPLAY=:0.0
Starting swblm daemon...OK
Project '/home/pvlab/synopsys/STDB/tmp1.pro'
Loading global tool database '/home/pvlab/synopsys/sentaurus/bin/../tcad/current/lib/glib2/tooldb.tcl'
Loading preferences '/home/pvlab/synopsys/STDB/gpref2_pvlab.H-2013.03'...
05:06:47 Mar 29 2016 <tmp1.pro> submitted to the batch system
Loading global queue configuration file '/home/pvlab/synopsys/sentaurus/bin/../queues/gqueues.dat'...ok
Loading project tree '/home/pvlab/synopsys/STDB/tmp1.pro/gtree.dat'
>>>>>preprocessing the project for running in intelligent mode
INITIALIZING PREPROCESSOR:
Loading project variables '/home/pvlab/synopsys/STDB/tmp1.pro/gvars.dat'
ERROR: impossible to determine the toolflow
05:06:47 Mar 29 2016 <tmp1.pro> failed: nok
>>>>>> Writing to status file 0
 楼主| 发表于 2016-3-29 21:52:05 | 显示全部楼层
然后查看err文件 里面写的 gsub exits with status 1
发表于 2018-3-6 15:59:30 | 显示全部楼层
遇到同样问题,楼主解决了么
发表于 2019-8-6 09:49:48 | 显示全部楼层
我也遇到同样的问题,怎么解决的
发表于 2021-11-18 19:36:01 | 显示全部楼层
楼主大大,我想问一下您会在sentaurus 里面产生晶粒嘛
GMT+8, 2025-12-23 10:18 , Processed in 0.022815 second(s), 6 queries , Gzip On, Redis On.
