查看: 3669|回复: 1
[求助] 求助:vivado综合失败
发表于 2016-3-28 14:33:18 | 显示全部楼层 |阅读模式
新建立工程project_2,程序如下,很简单的测试程序
module project_2(
     clk,
     c,
     d,
     e
    input clk ;
    input c;
    input d;
    output e ;
    reg e ;
always @(posedge clk)
begin
   e <= c +d ;
end
endmodule
保存后综合点击RUN SYNTHESIS,提示synthesis failed
log:
*** Running vivado
    with args -log project_2.vds -m64 -mode batch -messageDb vivado.pb -source project_2.tcl
****** Vivado v2014.3.1 (64-bit)
  **** SW Build 1056140 on Thu Oct 30 17:03:40 MDT 2014
  **** IP Build 1028902 on Fri Sep 26 17:35:13 MDT 2014
    ** Copyright 1986-2014 Xilinx, Inc. All Rights Reserved.
couldn't read file "project_2.tcl": no such file or directory
INFO: [Common 17-206] Exiting Vivado at Mon Mar 28 14:37:09 2016...
换了下载的官方程序也是同样的问题,之前是好用的,不知道动了什么现在不好用了,求帮助
发表于 2016-3-28 18:02:40 | 显示全部楼层
没有遇到过,不知道,不过你可以把测试工程放上来,让别人帮忙看看
GMT+8, 2025-12-12 04:55 , Processed in 0.016633 second(s), 7 queries , Gzip On, Redis On.
