查看: 2071|回复: 0
[招聘] Hardware engineer
发表于 2016-3-9 15:59:49 | 显示全部楼层 |阅读模式
职位描述:
job description
Under the responsibilities of the R&D Manager, you will be charged with analyzing, developing and designing the Hardware of our products. You will handle following tasks:
• PCB / PCBA Design
Technical solution advising and choosing (cooperation the embedded system engineers)
Schematic design based on the requirements
Components selection (type, brand, part number, etc.). Including cost and industrialization study
Perform CAD hardware simulation to make sure the solution will work / will be in line with the requirements
Layout and routing (components placement in highly constrained mechanical shell, multiple layers, etc.…)
• Prototyping
In charge of the prototypes manufacturing and assembly
Testing all HW functions of the prototype (using multimeter, scope, etc.).
Guarantee the compliance of the electronics with the relevant standards (CE, UL, CCC, etc.).
• Project Management:
Discuss and debate the requirements with the customers and the embedded system engineers
Capable or providing clear and efficient planning to management and customers
Able to handle pressure and keep the planning
工作要求:
Position Requirements:
- Master Degree in Electronic Engineering or equivalent
- Strong experience (5 to 8 years) in the design of PCB/PCBA
          o Multi-layers design
          o EMI/EMC management
          o Radio frequency PCB / Antenna integration
          o Small space design / Low power products
          o High voltage (230V / 16A) design
- Fluent in English
- Passionate of new technologies.
- Extra requirements
o Software knowledge (to support embedded system engineers in case)
o Antenna design
contact :linda@technochina.cn
GMT+8, 2025-12-13 06:37 , Processed in 0.017520 second(s), 7 queries , Gzip On, Redis On.
