查看: 2056|回复: 0
[原创] new test
发表于 2016-2-17 20:44:14 | 显示全部楼层 |阅读模式
经过两天的折腾终于看到功能覆盖率的报告了
  本人初学,欢迎讨论、批评指正。希望对大家有帮助。
提示一
covergroup里的option.per_instance一定要设成1(默认是0,不保存覆盖率数据),
option.per_instance = 1;  为了这个调试了两天,cadence的工具也不给个提示。。。
当然也可以在ccf(coverage configuration file)里设置全局的参数,如下:
select_functional
set_covergroup -default_goal 100
set_covergroup -per_instance_default_one
提示二
仿真命令,希望对大家有帮助
irun \
-svseed random \
-access +rwc \
-coverage functional \
-covfile cov.ccf \
-uvm \
-uvmhome /home/bill/asic/INCISIV10.20/tools/uvm-1.1/uvm_lib/uvm_sv \
+UVM_TESTNAME=my_test2 \
$(SRC)
提示三
用iccr查看和分析覆盖率时,合并多次覆盖率数据的命令需注意:
1. load_test *   直接用“*”就行,如果一定要指定文件名,请指定文件夹的名字test_sv-xxxxxxxxx(cov_work/scope/test_sv-xxxxxxxxx/icc_xxxxxxxx_xxxxxxxx.ucd)
2. merge test_sv-* -output all
提示四
1. covergroup cg;
    endgroup
    cg = new(); 别忘了用new来初始化covergroup哦。
2. 使用covergroup cg;不带采样控制的语句时(带采样控制是这个样子covergroup cg @(posedge clk); ),
需要在uvm_monitor里使用cg.sample()来采样。
3. 可以使用cg.coverage()来取得实时的覆盖率情况,进而调整约束和控制仿真的结束。
代码如下:
CODE:
class my_subscriber extends uvm_subscriber #(my_transaction);
  `uvm_component_utils(my_subscriber)
  // has implicit analysis_export
  bit reset;
  bit [3:0] cmd;
  bit [7:0] addr;
  bit [7:0] data;
  covergroup cover_bus; //covergroup is like construct
    option.goal = 100;
    cov_reset: coverpoint reset { bins r1[] = {[0:1]}; }
    cov_cmd_0: coverpoint cmd[0] { bins c0[] = {[0:1]}; }
    cov_cmd_1: coverpoint cmd[1] { bins c1[] = {[0:1]}; }
    cov_cmd_2: coverpoint cmd[2] { bins c2[] = {[0:1]}; }
    cov_cmd_3: coverpoint cmd[3] { bins c3[] = {[0:1]}; }
    cov_addr_0: coverpoint addr[0] { bins a1[] = {[0:1]}; }
    cov_addr_1: coverpoint addr[1] { bins a2[] = {[0:1]}; }
    cov_addr_2: coverpoint addr[2] { bins a3[] = {[0:1]}; }
    cov_addr_3: coverpoint addr[3] { bins a4[] = {[0:1]}; }
    cov_addr_4: coverpoint addr[4] { bins a5[] = {[0:1]}; }
    cov_addr_5: coverpoint addr[5] { bins a6[] = {[0:1]}; }
    cov_addr_6: coverpoint addr[6] { bins a7[] = {[0:1]}; }
    cov_addr_7: coverpoint addr[7] { bins a8[] = {[0:1]}; }
    cov_data_0: coverpoint data[0] { bins d0[] = {[0:1]}; }
    cov_data_1: coverpoint data[1] { bins d1[] = {[0:1]}; }
    cov_data_2: coverpoint data[2] { bins d2[] = {[0:1]}; }
    cov_data_3: coverpoint data[3] { bins d3[] = {[0:1]}; }
    cov_data_4: coverpoint data[4] { bins d4[] = {[0:1]}; }
    cov_data_5: coverpoint data[5] { bins d5[] = {[0:1]}; }
    cov_data_6: coverpoint data[6] { bins d6[] = {[0:1]}; }
    cov_data_7: coverpoint data[7] { bins d7[] = {[0:1]}; }
  endgroup: cover_bus
  function new(string name, uvm_component parent);
    super.new(name, parent);
    //new covergroup
    cover_bus = new();
  endfunction: new
  function void write( my_transaction t);
    reset = t.reset;
    cmd = t.cmd;
    addr = t.addr;
    data = t.data;
    //covergroup sample values
    cover_bus.sample();
    $display("my_subscriber| cmd = %h, addr = %h, data= %h, cov=%d\%",
                 cmd, addr, data, cover_bus.get_coverage());
  endfunction: write
endclass: my_subscriber
class my_monitor extends uvm_monitor;
  `uvm_component_utils(my_monitor)
  //declare analysis port
  uvm_analysis_port #(my_transaction) aport;
  virtual dut_if dut_vi;
  endfunction: new
  function void build_phase(uvm_phase phase);
    super.build_phase(phase);
    //new aport instance
    aport = new("aport", this);
    //get dut_if
    assert( uvm_config_db #(virtual dut_if)::get(this, "", "dut_vi", dut_vi) );
  endfunction: build_phase
  task run_phase(uvm_phase phase);
    forever
    begin
      my_transaction tx;
      @(posedge dut_vi.clock);
      tx = my_transaction::type_id::create("tx");
      tx.reset = dut_vi.reset;
      tx.cmd = dut_vi.cmd;
      tx.addr = dut_vi.addr;
      tx.data = dut_vi.data;
      //send tx through analysis port
      aport.write(tx);
    end
  endtask: run_phase
endclass: my_monitor
GMT+8, 2025-9-19 12:49 , Processed in 0.012088 second(s), 4 queries , Gzip On, Redis On.
