查看: 4725|回复: 7
[求助] 有关Hspice的一些问题,请大师解答,先谢谢了。
发表于 2016-2-11 03:16:42 | 显示全部楼层 |阅读模式
  1. RING OF THREE, FIGURE 9.1C
  2. V1 1 0 0 AC 1.0
  3. R1 1 2 10K
  4. C1 2 0 159PF
  5. E1 3 0 2 0 -10
  6. R2 3 4 10K
  7. C2 4 0 159PF
  8. E2 5 0 4 0 -10
  9. R3 5 6 1
  10. R4 6 0 10K
  11. E3 7 0 6 0 -10
  12. R5 7 2 10K
  13. .AC LIN 41 1MEG 5MEG
  14. .PLOT AC VM(7)
  15. .WIDTH OUT=80
  16. .END
    复制代码
这其中WIDTH OUT=80是什么意思?
2.
  1. ECP OSCILLATOR WITH C DIVIDER, FIGURE 10.18
  2. LL 6 5 2.39UH
  3. RC1 6 2 1
  4. RB1 1 0 1K
  5. Q11 2 1 10 MOD1
  6. Q12 5 7 10 MOD1
  7. RB2 7 0 1
  8. VCC 6 0 10
  9. CL2 6 1 2120P
  10. CL1 1 5 111.58P
  11. RL 6 5 3K
  12. IEE 10 13 4MA PULSE 3MA 4MA 0 0 0 1S
  13. VEE 13 0 -10
  14. *.TRAN 5N 300N
  15. .TRAN 5N 5000N 4800N 5N
  16. .PLOT TRAN V(9)
  17. .PLOT TRAN I(VC2)
  18. .FOUR 10MEGHZ V(5)
  19. .MODEL MOD1 NPN BF=100 IS=1E-16
  20. *+ TF=0.3N
  21. *+CJC=0.5P CJE=0.5P
  22. *+VA=50
  23. *+RB=100
  24. .WIDTH OUT=80
  25. .OPTION NOPAGE NOMOD LIMPTS=1000
  26. .OPTIONS RELTOL=1E-4 ITL5=0
  27. .END
    复制代码
其中OPTIONS RELTOL=1E-4 ITL5=0这是什么意思?
还有代码里的MODEL,一般是在哪里下载?有些软件需要原始参数,但我不知道去哪个网站下载,望说详细一点,再次感谢。
 楼主| 发表于 2016-2-11 03:18:00 | 显示全部楼层
初学hspice,小白问题请谅解。最后祝大家新年快乐,万事如意,天天开心。^_^
发表于 2016-2-11 12:11:50 | 显示全部楼层
Print Control Options
.OPTION CO for Printout Width
The number of output variables printed on a single line of output is a function of the number of columns, set by the option CO. Typical values are CO = 80 for narrow printouts and CO = 132 for wide printouts. CO = 80 is the default. The maximum number of output variables allowed is 5 per 80-column output and 8 per 132-column output with twelve characters per column. Star-Hspice automatically creates additional print statements and tables for all output variables beyond the number specified by the CO option.
.WIDTH Statement
Syntax
        .WIDTH OUT = {80 |132}
where OUT is the output print width
Example
        .WIDTH OUT = 132 $ SPICE compatible style
.OPTION CO = 132 $ preferred style
Permissible values for OUT are 80 and 132. OUT can also be set with option CO.
发表于 2016-2-11 12:12:25 | 显示全部楼层
回复 2# zhengbo12128
Print Control Options.OPTION CO for Printout Width
.WIDTH StatementSyntax
Example
 楼主| 发表于 2016-2-11 13:11:30 | 显示全部楼层
请大家帮帮忙,谢谢了
发表于 2016-2-13 04:59:38 | 显示全部楼层
谢谢分享
发表于 2016-2-13 05:14:03 | 显示全部楼层
谢谢分享
 楼主| 发表于 2016-2-17 00:07:37 | 显示全部楼层
谢谢你的解答。
GMT+8, 2025-12-28 17:42 , Processed in 0.022671 second(s), 5 queries , Gzip On, Redis On.
