查看: 2150|回复: 1
[招聘] 后端好职位(实习生,应届生,Sr.Engineer, leader Engineer)
发表于 2016-2-1 20:32:09 | 显示全部楼层 |阅读模式
1. 实习生招聘
Magic-semi JD forIntern
Magic-semi is a new startup design servicecompany specialized in backend training, consulting and design service. In magic-semi, design experters with rich experience in advancetechnology nodes from 40nm to 14nm and can deliver complete solutionfrom netlist to GDSII.   Magic-semi has good relationship with IC leadingcompany and enables our customer to achieve success in a more efficient,reliable and cost-effective way.
RESPONSIBILITES:
1. Responsible for developing digital designswith emphasis on backend, including Floor-plan, power planning, Place, CTS andRoute.
2. Work with Front-end designers to optimizetiming/area/power of the design implementation and perform static timinganalysis.
3. Optimization and Verification of layoutfor tape-out (including RC extraction, ECO, DRC, LVS).
4. Static Timing analysis (Prime Time or ETS)and setup/hold fix.
Requirements:
1.
CS/EE or background in areas related todigital or analog chip design
2.
Known of IC backend flow.
3.
Known of timing concept.
4.
Have reading and writing skills forenglish
5.
Experience in floorplan, place, cts,route, timing ,pv and power analysis and so on.
6.
Experienced in Synopsys/Cadenceautomatically physical implementation tools and flows (IC-Compiler/ Astro /SOC-Encounter/ Milky-way/ Star-RCX) is a plus.
7.
Experience with one or more scriptinglanguages (Perl, TCL, or Shell) to make reusable automatically flow is a plus.
8.
Experience and knowledge about FE design(RTL code, flow) and verification is a plus.
9.
Good analytical and debugging skills.
Send your CV to hr@magic-semi.com if you are interested.
 楼主| 发表于 2016-6-5 15:38:21 | 显示全部楼层
郑重声明, magic-semi中文名上海实真微电子有限公司,不是收费培训公司,是招聘的正式员工和实习生,欢迎您的加入
之前发的帖子的楼歪了,给一些人造成了一些误解,先郑重声明:
GMT+8, 2025-12-26 05:15 , Processed in 0.017198 second(s), 5 queries , Gzip On, Redis On.
