查看: 1842|回复: 0
[招聘] Cadence招聘信号完整性产品验证工程师
发表于 2016-1-29 17:48:40 | 显示全部楼层 |阅读模式
Title: Lead PV Engineer-Sigrity and Allegro PCB SI(信号完整性)
Location SH
更多职位信息敬请关注Cadence公众微信平台:Cadence微招聘
If you haveinterest, PLS send your update CV to job_china@cadence.com
Position Description:
Introduction
We are looking for a signalintegrity engineer with 1-5 years of experience in High Speed design. You willbe responsible for testing and overseeing the quality management of our familyof software products that deal with SI design.
Duties
You will work within a globalmulti-functional team to review project plans and functional specifications,develop test criteria and written test plans, manually exercise and testfunctionality of the Allegro PCB SI and Sigrity products and develop automatedtests within the existing test environment. As this position requires a goodunderstanding of the signal integrity knowledge. You will maintain regressiontests and evaluate results on a regular basis.
Position Requirements:
Requirements
-BS Degree is required, MS ispreferred
-Working experience with the Sigritytools is strongly desired
-Solid understanding of thefollowing: signal integrity, modeling and simulation
-Recent experience with signalintegrity tool is a must
-Knowledge of other PCB design,routing, and packaging is a plus
Experience
-Knowledge of Windows and Linuxplatforms is essential
-Any experience in softwarevalidation
-Programming knowledge in Perl isstrongly desired
-Experience with an error trackingand reporting product is valuable
Basic Abilities
-Strong written and verbalcommunication skills, in English and Chinese are mandatory as the candidatewill be interacting with a global team based in the US and China.
-Ability to follow a schedule isessential
-Familiarity with softwaredevelopment life cycle is a plus
-Ability to detect, report andexplain defects effectively is crucial
-Possess good analytical, problemsolving skills
-Understand test processes andmethodologies in a software development environment
-Self-starter, self-sufficient, ableto work independently as well as with teams, able to multitask
GMT+8, 2025-12-29 11:07 , Processed in 0.018821 second(s), 6 queries , Gzip On, Redis On.
