查看: 5449|回复: 6
安装cadence IC616出错
发表于 2016-1-27 13:14:43 | 显示全部楼层 |阅读模式
各位大侠,在安装cadence IC616时候显示如下错误,有知道是怎么回事的么?求教呀~
Errors during installation.
    Detailed error information is in the following file:
    /root/.iscape/iscape_logs/20160127_125440_run.txt
The following selected products were NOT installed:
    111:Cadence(R) Design Framework II
    12141_64bit:12141_64bit~06.14.001~lnx86
    12141:Cadence(R) Design Framework Integrator's Toolkit
    206:Virtuoso(R) Simulation Environment
    207:Waveform
    21060:Virtuoso(R) Schematic VHDL Interface
    21400:Virtuoso(R) Schematic Editor Verilog(R) Interface
    276:Virtuoso(R) Schematic Editor HSPICE Interface
    32100:Virtuoso(R) Analog Oasis Run-Time Option
    32101:Cadence(R) OASIS for RFDE
    32760:Virtuoso(R) Analog HSPICE Interface Option
    365_64bit:365_64bit~06.14.001~lnx86
    365racula(R) Graphical User Interface
    5100:Virtuoso(R) Layout Migrate
    681:Cadence(R) RC Network Reducer Option
    70000:Virtuoso(R) AMS Designer Environment
    70110_64bit:70110_64bit~06.14.001~lnx86
    70110racula(R) Design Rule Checker
    70120_64bit:70120_64bit~06.14.001~lnx86
    70120racula(R) Layout Vs. Schematic Verifier
    70130_64bit:70130_64bit~06.14.001~lnx86
    70130:Dracula(R) Parasitic Extractor
    70510_64bit:70510_64bit~06.14.001~lnx86
    70510:Dracula(R) Physical Verification Suite
    70520_64bit:70520_64bit~06.14.001~lnx86
    70520:Dracula(R) Physical Verification and Extraction Suite
    71110_64bit:71110_64bit~06.14.001~lnx86
    71110:Diva(R) Design Rule Checker
    71120_64bit:71120_64bit~06.14.001~lnx86
    71120:Diva(R) Layout Vs. Schematic Verifier
    71130:Diva(R) Parasitic Extractor
    71510:Diva(R) Physical Verification Suite
    71520:Diva(R) Physical Verification and Extraction Suite
    900:Cadence(R) SKILL Development Environment
    940:Virtuoso(R) EDIF 200 Reader
    945:Virtuoso(R) EDIF 200 Writer
    95100:Virtuoso(R) Schematic Editor L
    95115:Virtuoso(R) Schematic Editor XL
    95120:Virtuoso(R) Schematic Editor GXL
    95200:Virtuoso(R) Analog Design Environment L
    95210:Virtuoso(R) Analog Design Environment XL
    95220:Virtuoso(R) Analog Design Environment - GXL
    95255:Virtuoso(R) Visualization & Analysis XL
    95300_64bit:95300_64bit~06.14.001~lnx86
    95300:Virtuoso(R) Layout Suite L
    95310:Virtuoso(R) Layout Suite XL
    95311:95311
    95320:Virtuoso(R) Layout Suite - GXL
    95510:Virtuoso Implementation Aware Design Option
    95610:Virtuoso EAD Advanced Electrical Analysis
    95620:Virtuoso EAD Advanced Electrical Analysis
    994ostScript Level 2 Hardcopy Output
    VPS100:Virtuoso Power System - L
    VPS200:Virtuoso Power System - XL
The following components were NOT installed:
    All component files are relative to:
       /home/zxp/download/Cadence/deCaVirI616S8/HotfixIC06/CDROM1
      Error Installing Component:amsenvugDoc 06.16-s011, File:kits/amsenvugDoc06.16-s011.t.Z
Exception Information:
Exception Message:amsenvugDoc 06.16-s011:IO Exception while extracting file /home/zxp/download/Cadence/deCaVirI616S8/HotfixIC06/CDROM1/kits/amsenvugDoc06.16-s011.t.Z (tarEntry)
com.khanpur.util.tar.ISTarIOException:IO Exception while extracting file /home/zxp/download/Cadence/deCaVirI616S8/HotfixIC06/CDROM1/kits/amsenvugDoc06.16-s011.t.Z (tarEntry)
发表于 2016-1-27 13:24:46 | 显示全部楼层
文件不完整吧
 楼主| 发表于 2016-1-27 14:02:10 | 显示全部楼层
回复 2# toad
  是amsenvugDoc06.16-s011.t.Z这个文件不完整么?
已经下载好多个版本软件了,都安装不成功~~
发表于 2016-9-10 11:11:00 | 显示全部楼层
搂住解决了吗?单独装Base没问题,如果装hotfix我和搂住错误一样。本论坛看上去只有两种HOTFIX,都下载下来了,还是抱错。
发表于 2016-12-3 23:28:12 | 显示全部楼层
回复 1# zxpg05
不知楼主问题解决了没有?我也出现了类似于第一个的问题111:Cadence(R) Design Framework II不能被找到
发表于 2023-7-20 16:18:51 | 显示全部楼层
我第一遍装ic618没问题 所以我确定安装包是没问题的 但是我第二遍换了个安装路劲用相同的安装包装的报了一样的错
搞不懂为啥
发表于 2023-7-21 09:01:55 | 显示全部楼层
咸鱼有卖的软件全套
GMT+8, 2025-12-26 04:24 , Processed in 0.021045 second(s), 6 queries , Gzip On, Redis On.
