查看: 8190|回复: 18
安装DC遇到问题
发表于 2016-1-20 12:17:09 | 显示全部楼层 |阅读模式
新人按照教程来安装。license生成应该是正确的,sssverify显示PASSED       Integrity check report for license file "/eda/synopsys/license/synopsys.dat".
       Report generated on 20-Jan-2016 (SCL_10.9.3)
       Checking the integrity of the license file....
       Valid SSS feature found.
       License file integrity check PASSED!
但是运行dc&,显示
       [ld@localhost ~]$ dc&
       [1] 16970
       [ld@localhost ~]$ Fatal: Design Compiler is not enabled. (DCSH-1)
运行dv&,显示
       [1] 16996
       [ld@localhost ~]$
       [ld@localhost ~]$ Unable to obtain feature 'Design-Vision ' because:
       Error: Can't communicate with the license server. (SEC-12)
       Please contact  at ld@(none), who is
       your local Synopsys license administrator for Synopsys site 000.
       Unable to obtain feature 'Design-Analyzer-DAP ' because:
       Unable to obtain feature 'Design-Analyzer ' because:
       Fatal: At least one of the following must be enabled : Design-Vision, Design-Analyzer-DAP, Design-Analyzer. (DCSH-10)
syn_lic.log显示
       (snpslmd) Licenses are case sensitive for TE_CATS
       (snpslmd)
       (snpslmd) EXTERNAL FILTERS are OFF
       (lmgrd) snpslmd using TCP-port 32918
       (snpslmd) Serving features for the following vendor names:
       snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  archprod  avantd  chrysalisd  everest  hscd          innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2     snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synopsysd  tmald  vcsd
       (snpslmd) ------------------------------------------------------------------
       (snpslmd) Checking the integrity of the license file....
       (snpslmd) Valid SSS feature found.
       (snpslmd) The feature is needed to enable the other keys in your license file.
.brshrc文件环境是
      #synopsys
      export SYNOPSYS=/eda/synopsys/dc2007
      export SNPSLMD_LICENSE_FILE=66666@localhost.localdomain
      export LM_LICENSE_FILE=66666@localhost.localdomain
      export PATH=/eda/synopsys/dc2007/binPATH
      export PATH=/eda/synopsys/scl/10.9.3/linux/binPATH
      alias lmli2="lmgrd -c /eda/synopsys/license/synopsys.dat -l /eda/synopsys/syn_lic.log"
      alias dc="dc_shell"
      alias dv="design_vision"
DC装的是2007,2010也试过,scl用的是10.9.3
发表于 2016-1-22 12:10:53 | 显示全部楼层
port有设正确吗?感觉根本没有向服务端申请license啊
 楼主| 发表于 2016-1-30 14:38:41 | 显示全部楼层
回复 2# daviehj
发表于 2016-2-1 14:53:38 | 显示全部楼层
you're welcome
发表于 2016-5-23 15:20:28 | 显示全部楼层
回复 3# leoLD
   请问你这个问题怎么解决的? 怎么添加的串口?
发表于 2016-5-23 15:28:15 | 显示全部楼层
回复 2# daviehj
   请问怎么解决这个问题?先谢谢你
发表于 2016-5-23 18:19:36 | 显示全部楼层
谢谢分享!!
发表于 2017-8-16 14:22:35 | 显示全部楼层
发表于 2018-1-9 09:29:17 | 显示全部楼层
发表于 2018-1-9 09:30:46 | 显示全部楼层
GMT+8, 2025-12-21 17:29 , Processed in 0.023937 second(s), 7 queries , Gzip On, Redis On.
