楼主: min4max
Cadence全套新版IC工具套件(2015年底版本),包括IC617以及其他工具套件
发表于 2017-5-12 18:48:59 | 显示全部楼层
这么全啊!收藏先
发表于 2017-5-18 16:12:01 | 显示全部楼层
楼主好人,感谢分享
发表于 2017-5-22 19:51:57 | 显示全部楼层
see see
发表于 2017-5-23 13:49:13 | 显示全部楼层
学习下怎么安装cadence
发表于 2017-5-25 15:25:11 | 显示全部楼层
good ------------
发表于 2017-5-25 23:24:17 | 显示全部楼层
多谢。。。。
发表于 2017-5-26 10:06:20 | 显示全部楼层
麻烦楼主给看下这是什么问题? 不能够运行,谢谢了
/Cadence/ET151/tools.lnx86/tb/tcl/main/guiMainForm.tcl
Error in startup script: invalid command name "TCM::defineCmdArg"
    while executing
"TCM::defineCmdArg set_context {
  {string -testmode "Specify the name of test mode." testmode 0 1}
  {string -experiment "Specify the name of the expe..."
    (in namespace eval "::analysis_context" script line 30)
    invoked from within
"namespace eval analysis_context {
  # Only the commands which are exported from ..."
    (file "/opt/Cadence/ET151/tools.lnx86/tb/tcl/framework/../reports/analysis_context.tcl" line 30)
    invoked from within
"source $dir/../reports/analysis_context.tcl"
    (procedure "Framework_init" line 87)
    invoked from within
"Framework_init"
    (file "/opt/Cadence/ET151/tools.lnx86/tb/tcl/framework/fwinit.tcl" line 229)
    invoked from within
"source /opt/Cadence/ET151/tools.lnx86/tb/tcl/framework/fwinit.tcl"
    ("package ifneeded Framework 1.0" script)
    invoked from within
"package require Framework        "
    (file "/opt/Cadence/ET151/tools.lnx86/tb/tcl/methodology/meth_cmds.tcl" line 324)
    invoked from within
"source /opt/Cadence/ET151/tools.lnx86/tb/tcl/methodology/meth_cmds.tcl"
    ("package ifneeded Methodology 1.0" script)
    invoked from within
"package require Methodology"
    invoked from within
"if { [info exists env(Install_Dir)] } {
   ## Source GUI init file to setup auto_path (use TCL_PATH)
   foreach dir [split $env(TCL_PATH) :] {
    (file "/home/weidebo/.testderc" line 2)
    invoked from within
"source $::env(TESTDE_RSRC)"
    (file "/opt/Cadence/ET151/tools.lnx86/tb/tcl/main/guiMainForm.tcl" line 221)
发表于 2017-5-26 14:43:08 | 显示全部楼层
Thanks for your share.
发表于 2017-5-26 16:34:11 | 显示全部楼层
这个太强大了,威武
thanks!
发表于 2017-5-29 22:05:13 | 显示全部楼层
Thanks Guys...
GMT+8, 2025-12-30 19:16 , Processed in 0.018612 second(s), 3 queries , Gzip On, Redis On.
